401 - 416 of 416 Posts
I have been wanting to do the 2 DIN upgrade for so long using one of the newer Pioneer units that support Android Auto wireless, but I am hesitant to pull the trigger as I have not yet seen anyone post about doing it and how it works. My main goal would be to have all the modern features of the new head unit, have it plug and play without any messing around with resetting things, allow me to use the Torque App on the screen (screen share), and not need to do anything on my phone...just get in start the engine and it all connects and works. I know that Crutchfield shows most 2 DINs won't fit, but from reading this and other threads it seems you can make the larger 2 DINs fit with a little bit of trimming of plastic.
Double dins aboslutely fit. The trimming you do for the metra kit, leaves so much room back there. There is a TON of room. I went with an alpine ILX series double din, and its so nice to have everything connect the second I get in the car, I never touch my phone, and it all works. Steering wheel controls work as well. Other than my dashlogic issue, this is an absolute must have upgrade.
I'll have to check out the Alpine. Do you use Android or iPhone with it? Using it with stock amp and speakers? I am using a Bluetooth OBDII adapter with my Torque app. It sounds like I may also have issues with that. Is it that the Metra plugs into the OBDII also that causes Dashlogic to break?
Sent from my SM-G955U using Tapatalk
Alpine is apple play, but was just more of an example of whats possible with something more modern. The dashlogic works, but then interferes with the metra interface and the sound stops, and AC stops working. Something in the system doesnt like it, its likely accessing the same things.
I see. So basically any 2 DIN is likely going to fit once you do the trimming for the Metra kit. Did you notice better sound quality with the Alpine (assuming you are running stock amp and speakers)? In the past just replacing my stock head unit always gave me much better sound over stock. How was the install over all? I plan on doing a DIY install, but gotta sort out the camera setup since I am a 2010 with no factory camera wiring.
Its not bad, I used this thread for all the info, its all in here. I also added a camera, which was really easy. Running cables in this car is very simply.
So I have been asked several times to do a writeup on this whole process...so here it goes. I have been wanting to put a legit audio source in my car ever since I owned it. The only thing I really don't like about the V's is the horrible nav and Bose setup. Even with using a separate audio processor, the Bose system is so integrated into the car that you can never fully get around it. The processors try to do what they can to normalize the signal but the Bose setup changes it off the fly based off volume so you never get a clean signal out of the car. It is also integrated into your door chimes and other factory car systems...so you couldn't delete it either. Metra finally came out with a kit that would keep all of your stock functions thank to their modules / harnesses but also install a double DIN headunit. This makes it so that I now have 4v RCA outs I can run to my processor that is completely clean of the Bose setup in the car.
So I chose the AppRadio 4 from Pioneer for several reasons. First, it is the cleanest looking headunit you can buy because it is essentially just a screen. I don't know why, but the radio industry has gone back away from the OEM+ look when it comes to design, buttons and UX. I wanted to keep the interior looking as OEM as possible so the radical looking buttons was out. Second, I didn't want to relocate the Aeroforce gauge that was in the factory clock location. DashCommand is AppRadio compatible so I could run gauges on the screen itself. Lastly, I wanted Apple CarPlay.
To run AppRadio / DashCommand, you use the HDMI port on the Pioneer. That requires the HDMI / Lightning adapter. To run CarPlay, you use the USB port. That takes just a regular iPhone cable and the USB extension provided with the Pioneer unit. To get the ODB2 signal to the phone, you use a wifi OBD2 dongle. If you have an Android phone, you would need a bluetooth one. I have not tested any of this with an Android phone.
Parts needed:
Removal
To start, you have to remove the factory unit and the motorized screen.
Kit Install
The kit install is pretty straight forward after you get everything apart. You do have to cut a section of the gray plastic part where the clock used to be to clear the double DIN headunit but that is the only modification of anything you have to do. There are two harnesses for the Metra setup that connect to the Pioneer harness. The instructions are easy if you have ever touched a wire in your life. The Metra kit is pre-wired for the steering wheel control unit so you just plug the box in and throw away the harnesses provided with that unit. When you initialize the radio for the first time, you leave that unplugged. After the radio is setup, you plug it in and follow the sequence provided in the instructions. It does auto detect our cars so there is no manual programing. You essentially just hit the volume up button on the steering wheel a bunch of times until it recognizes it.
Installed
Apple CarPlay
DashCommand Modified
I downloaded the DashXL skin program to modify the dashboard setup. The program does allow you make gauge pages but they look terrible. I wanted the info I needed on the dashboard setup that looks much better. I was able to modify the existing skin to include IAT2's and Oil Temps. You can download it through the app on DashXL. Dashboard Details - DashXL.net
A couple of notes:
  • I have not hooked up the amps yet but I did test the system through the factory rear speakers. Everything functions as it should.
  • The nav/radio buttons on the center console no longer work. They are not apart of the same system as the steering wheel controls. They are wired into the main harness. The rest of the buttons function as normal. This wasn't a big issue to me as I never used those buttons anyway. Obviously the CD slot now goes to nothing. The Pioneer AppRadio does not have a CD slot so there is no longer one in the car at all. I never use CD's and I store any videos on my iPhone so this was not a big deal to me either.
  • The Metra kit does match the factory interior very well.
It looks like there are new Pioneer units, what is the maximum size of the screen that will fit?
I looked it up and this popped up, not sure it'll fit with the metra kit...any word?
If it helps for comparison purposes, I'm running a Pioneer DMH-W4660NEX with the Metra kit without issue. Probably has another 1/2" or so clearance behind it if need be.
Edit: just realized that one has a built in CD/DVD slot? If so, I suspect it's not going to fit. The reason the DMH-xxx fits is that there are two different boxes that get installed which cuts down on the screen unit depth significantly.
Just upgraded from the Navtool, I had it in for about 2 years now and it did what it was supposed to. That said, the lack of mic audio quality, and buttons working on the steering wheel was annoying. However the single biggest issue was the frequent “crash” of the Navtool, at least a few times a week it would become non responsive and I would loose access to everything including climate until I reset the unit by unplugging the power. I went with the Alpine ILX-207, the SQ is better than the stock radio. I will be adding a second amp for the mids and highs soon. I have 2 sets of Focal components going in. Install was very straight forward and the look is really growing on me.
Is there any way to retain the leather across the top?
Did you trim the Metra kit for the HU to sit flush... or is that a different kit? I haven't been following this thread in awhile and it may have been discussed.
I believe one member bought the replacement piece from GM and cut/spliced it on there. I think someone else just removed it from their OEM and glued it on.
