The front pinion bearing had the following markings on it
SKF BRAZIL 6W32F R6T1-0382/Q
The race was marked with the same but had 6W33E.
I bought a Timken HM802048 and it is the same dimensions. The tapered needle bearings themselves are a little smaller on the Timken bearing than the SKF. But the external dimensions are all the same.
Taking this thing apart was difficult. The flanges that the axles bolt to have a splined axle on the other side. The spline side of the axle flange is held in the limited slip carrier by c-clips. They are a pain to pry off without having special tools and a press. Once you can get the axle flanges out. The carrier with the ring gear comes off easily. The pinion needs to be pressed out. I beat on it with a dead blow hammer and it eventually came out. You'll need a bearing puller for the carrier bearings and the rear pinion bearing. The races seemed like they would be impossible to get out but then I saw a video online that said to weld on the face of the race. The race would shrink and it would fall right out. I used a TIG welder with no filler rod to eliminate sparks and spatter and it is definitely true. The races would fall right out when I flipped the diff over.
The carrier had 1 shim on the passenger side behind the pressed on bearing. The pinion had two shims behind the rear bearing that were showing wear from moving. My guess is that my pinion bearings got no oil going up the steep incline, got hot, expanded and started to sieze. This wore away at the shims and ground then down. The pinion was then freed and backed out and started making contact on the toe of the ring gear, causing all the damage. All bearings showed a little sign of wear but the front bearing definitely had it worst. The front pinion bearing gets oil through a 1/4 in hole at the bottom of the casting. This hole is partially blocked by the race so the pinion bearings don't get much lube. The 75W-90 must become like water at those temps. I have changed the fluid multiple times on the diff and there is always a vacuum as I pull the check plug out. The breather is definitely not doing its job an something funky is going on. I am probably going to overfill next time and try and go with a thicker gear oil.
I am going to rebuild my old diff and try and get a good gear mesh. The toe of the pinion and ring are worn but that area should not be making contact with a good mesh.
I bought a shim kit that seems to be the correct size for the pinion bearings. I will post the part number if it's a good fit when it comes in.
Hopefully, this helps someone and gives them the motivation to tear their own apart.
