Power steering rack wiring
2 reading
60 views 3 replies 4 participants last post by  RocketSled
#1 ·
Hello by chance can any one out there please help me figure this power steering wiring issue I have a 2016 cts v, somehow my power steering rack wires got cut on one of the connections and am not sure what needs to be reconnected to what because all majority of the colors are the same (blue and white) if somone can show or let me know the correct Pinout for these wires. here is the connector and the wires if someone can please help me I would highly appreciate it and thank you in advance!
#2 ·
I will pour a little bourbon out in your honor - and send you the rest of the bottle to assist in your upcoming frustrations. Hopefully someone can give you a wiring diagram - and a voltmeter.
Ugh.
#3 ·
is there a part number on the harness?
is it a small jumper harness or part of the entire engine harness?
you can usually find some of the smaller harness for less than $100 bux on ebay or even new.
#4 ·
You need the other half of the connector to figure out which pins had which colors. Where's the other half?
To a reasonable degree of certainty, it doesn't matter which of the wires with the same color insulation connect to which respective pin for that color. The solid whites all carry the same signal/voltage, the blues w/yellow stripes all carry the same signal/voltage (different from the solid whites, obviously), etc., etc...
