Good afternoon. I’m just looking for some pros and cons with using the stock blower and M311 Frankenstein heads with either block. Thanks in advance
Yes, when you build the engine for 'Max / Peak HP' it can get very expensive..lolThat's why you're getting the echo when I say it. It's deep in here,
Just in case anyone wonders what sort of collateral damage ensues when you select the "427" checkbox....
click my sig line.
Depending on the camshaft & compression ratio you chose. . .Please see attached for head information. I only want to get 800whp. But if can make 850-875 easy, that’s what I want.
Ok got it. Higher compression equals more torque. Lower compression equals lower torque and higher horsepower from a bigger engine butDepending on the camshaft & compression ratio you chose. . .
yes those heads should be more than adequate for your new HP Goals..
However, I have been suggesting that you lose the HP Goals, which require high engine rpm, which in turn generate a higher 'mean / average' piston speed. High piston speeds are required for high HP goals, as they generate a high depression across the intake valve required to fill the cylinder. Your going to use a roots blower to fill the cylinder. And roots blowers, because they are driven from your crankshaft, push a lot of air into the cylinders at low engine rpm. NA Engines 'don't'. So why not build a large volume engine, and fill the cylinders at a low engine rpm, and generate huge amounts of torque.
HP is simply Torque multiplied by Engine RPM. . . .
Make it simple with a big volume engine:
Put sufficient compression in it, close the intake valve so as to hold high cylinder pressures at low engine rpm, and your big engine will generate much low engine rpm torque. Now you don't have to spin the engine high, and now you don't have to invest in lightweight valves, high open pressure valve springs, etc.
But you might have to invest in a bigger & better tire.
ok got it. So high compression equals more torque and a longer lasting engine. You mentioned the individuals you worked with for 5-8 years and the compression they went with was 11.0 to 11.25 or so. If I wanted 12.0;1 compression is that ok?Depending on the camshaft & compression ratio you chose. . .
Are you saying that compression is to high?![]()
YesAre you saying that compression is to high?
At this time i don’t know yet. I’m trying to get a better understanding of what to expect and to be pointed in the right directionWho is building your engine?
It's a learning process folks.![]()
Good Start; but the answer to your question is a bit more complex than that, as your engine has a roots blower on it. But let's start with; no you don't want 12.0:1 static compression in your engine..So this chart is about right then.
Lmbo 10-4Good Start; but the answer to your question is a bit more complex than that, as your engine has a roots blower on it. But let's start with; no you don't want 12.0:1 static compression in your engine..![]()
Depends on engine size, blower size, and primarily usage.It's a learning process folks.
Any of you can chime in with your thoughts.
Steve,
So, how much compression would you run.
Based on what variables.![]()
My posts, should, if I have done my job, stated don't go for big HP Numbers.Depends on engine size, blower size, and primarily usage.
Max of 11:1 on any street driven car…I rather leave money (power) on the table than parts on the ground.
But, if you are running races only and unlimited categories, have at it.
IMO, too many here of late get all caught up in big power numbers, and then, after 6-12 months of driving the car, realize while the car is really fast, it’s just not as much fun to drive a lot of hours in.
My gf’s Porsche 718 Boxter had a dead battery last weekend.
I was able to jump it and asked if she wanted to go for a drive? She said yes.
Now, it’s an automatic, but it’s a PDK…they are the shit.
I put it in sport mode, turned off the DRL and ac compressor, and went through some canyons, down to PCH (we had affogatos in Malibu…not a bad deal trying to charge the battery)…
I called her the next day and said that little car is a blast to drive.
It doesn’t overpower the tires (I did get a bit sideways once, at a lower speed), doesn’t overpower the roads like my V, and you can push pretty good without having to hit obscene speeds on the street.
Just my 2 cents from observing years of builds on this forum, talking to many owners, and having my own car.
On that note, I thought of more power, I have the resources to do it, but I realized I have no compelling reason to do so.
If the track was closer I might try hard to see if I could crack a 9.xx with some tuning and a lot of driving practice, but I’m already busy enough with other hobbies.
