101 - 120 of 244 Posts
Throw me in also......
2.4 Pulley, LS7tb, Air-Raid Red F.
Ethanol Addiction, B&B Test Pipes, B&B Cat-back W/2nd cats, QTP Cutouts
Varimax Pump, Dyno-Speed Racing Hx, KB Bap
Hx Reservoir, Vitesse Throttle Controller
Transmission Tune
DBR Performance, Spring Hill TN
740hp= 625whp/626 tq
Well that what they gave me after I gave them my money lol.....
Sent from my SCH-I605 using Tapatalk
Impressive numbers with relatively mild mods.
Hub dynos are notorious for reading higher than a rolling dyno.
Not saying the car doesn't make good power...but every dyno is different. On average, from what I have seen, the Hub dynos will read about 5 to 7 percent higher than a Dynojet. On a Mustang Dyno (typically around 10% lower than DynoJet), car would probably be around 530 to 540...DynoJet, about 580 to 590.
The proof will be in where the car runs down the track (or next to another ~625whp V2)...if you run (noticeably) slower than it, you don't make 625.
Overall Im happy with the car. Haven't really raced anyone to see where she stands.
Thanks for the info on dyno machines, I'm still new to the V world, still learning....
Yeah that's probably accurate.
2011 A6
605HP/560lb-ft on E60
Airaid cold air kit
Ported Supercharger from Dynamic Flow Concepts
Ported 90mm LS7 Throttle Body
2.55 Upper pulley only
ZL1 Lid
Varimax pump
Weapon X Track Attack Heat Exchanger
ID850 Injectors
DSX E85 conversion kit
Big Thanks to Matt at GP Tuning
Reactions: MYV and Lt1z
2011 CTS V Coupe 6MT
-2.5" Upper Pulley
-9.1" Lower Pulley
-2" Stainless Works Long Tube Headers
-Track Attack Heat Exchanger
-BMR Icebox/HX Expansion Tank
-ZL1 LID
-FIC1000 Injectors
-E85
-Dual DW300 Fuel Pumps
-New Era Intake
-Custom 3" Exhaust to Magnaflow Bullet Style mufflers to Dual 5" Tips
-Dyno'd at 655whp and 600tq on E85
2009 V Sedan Performance: 90 Degree day on 93 Octane Gas
New blower ported by Jokerz performance along with ported snout
2.5 Griptech upper pulley
9.1 Metco lower (15lbs of boost)
New reinforced intercooler brick
ID1050X injectors
American racing headers to off road X pipe
LS9 cam (drives like stock with a hint of lope)
Brian Tooley Racing valvetrain
160 thermostat
Moroso catch can
Upgraded HX
Air raid intake with green filter
New BR7EF plugs
AC Delco wires
New gates belt for blower and A/C
Reactions: MYV
Yikes , Throw that shit in the trash . Isnt that kerosene base??? Much much better option out there .
Just had mine tuned. Made 698 on a Mustang Dyno
Its similar to the BTR stage 3 cam. yes its on E65 about 60 degrees outside & my IAT's were around 110-125.
Please add mine to the 700 WHP group:
Vertigo: 2009 Auto CTS-V Sedan
o 770 RWHP @ 7096, 696 RWTQ @ 4788 (Mainline Prohub SAE, E85)
o Stock Short block – never opened
o No Nitrous
o 4L80e with 4200 Stall and brake
o 2.55" Upper Pulley
o 9.1" Lower Pulley
o 15 psi with Pulley combo
o Stainless Works 2" Headers w/3" Catless
o NGP - Low Lash Solid Hydraulic Roller Cam
o NGP 11* heads w/ LS7 valves - Ported
o OEM 1.9L Ported Blower/Snout - NGP
o TPiS 102mm Throttle Body
o 5" BMR Intake
o ZL1 lid with 12 AN and DMS Brick Mod
o DW 90 lbs Injectors
o D3 Ultracooler HX with Jabsco Pump
o Norcal 1.7 Gallon IceBox
o NGP 12 AN Catch Can
o Squash Fuel System – Twin 450 LPH Walbro E85
o DMS Flex
o Solid Isolator
o 160 T-Stat
o Tuned by Justin White
