221 - 240 of 244 Posts
2011 M6 Sedan
605.48 WHP 563 WTQ on DynoJet
Stainless Works Headers
Stainless Works Midpipe
Corsa Axle Back
Airaid Intake
Hennessey 9.55" lower/2" Idler
NGK Plugs
MSD Wires
85# Injectors
Tuned by RPM in NC
Added After Tune
Hobbs Brick
WeaponX HX
3/4" IC Lines
CWA 150 ICP
Dedicated 2gal Tank
2011 a6 coupe
(650whp 644wtq dynojet 93oct )
(700whp 688wtq dynojet with 93oct and dual nozzle #16 meth)
15.6 psi
Ported/polished snout and blower
102 nick William tb
Comp Gt9 cam
660 springs
2.30 upper pulley
8.60 lower pulley
DDP intake with grean 6inch filter
1.7/8 headers to stock muffler
Dedicated motorsport intercooler reinforced brick
Weapon x heat exchanger
Weapon x underhood ice tank
Weapon x 160 thermostat
Weapon x intercooler pump
Snow performance stage 2.5 methanol injection 100% vp m1 meth
2011 a6 coupe
15.6 psi
102 nick William tb
Comp Gt9 cam
660 springs
2.30 upper pulley
8.60 lower pulley
Are you going to drag race. If so, please post you times.
2011 a6 coupe
15.6 psi
102 nick William tb
Comp Gt9 cam
660 springs
2.30 upper pulley
8.60 lower pulley
What injectors are you running with this setup?
Very cool....so glad you drive a V instead of a BMW or Benz. Just sayin👍
Do you use drag radials when you race from a roll?
I hate those bmw and benz cars i’m all the way gm💪 And yes i used to have toyo’s r888r but they don’t hook will now i’m using mickey’s ss 305/35/19
2011 AUTO CTS-V SEDAN
617 RWHP, 631 RWTQ (DynoJet SAE 93 Octane)
677 RWHP, 631 RWTQ (DynoJet SAE E-60)
  • Texas speed long tube headers, straight piped
  • Airaid intake with green filter
  • 2.5
  • 8.6
  • Ported snout
  • 102 NW throttle body
  • 160 Thermostat
  • Fabtech HX
  • ZL1 LID with reinforced brick
  • Devin Bruce aux fuel pump
  • DSX flex fuel sensor
  • Fid 1300 Fuel injectors
  • BTR stage 3 torque cam
  • BTR .660 valve springs
  • Stock rockers with BTR trunion upgrade
  • Chromoly 7.4 pushrods
  • NGK TR7IX spark plugs
  • Melling 10355 oil pump
  • Built and tuned by Majestic Motorsports Jacksonville, North Carolina Area
2012 M6 Coupe
DYNOmite Dyno
627rwhp/669.7rwtq on e50
547rwhp/599.2rwtq on 93 octane
TSP Headers/Catless x-pipe
1000cc FIC
NGK 3346
2.4" upper (stock lower)
Flex Fuel Sensor
Airaid Intake
Low mount HX
Expansion tank
2011 BDE Coupe 1016HP
  • Manual trans
  • 427ci LSX block 4.125 bore
  • Brodix 4" crank
  • Mahle 9.2 cr pistons
  • Mast Black Label heads 2.25/160
  • Magnuson gen2 2650 SC
  • 9.58/3.0 pulleys
  • NW112 TB
  • DDP CAI
  • Fluidyne HX
  • trunk tank
  • Fore! triple pump system
  • ID1300XDS injectors
  • DynaTech 2" LTs
  • StageFright Cam
  • 1.8 rockers
  • Tuned at Dedicated Motorsdports
  • Mainline hub dyno
  • 1016HP @6947 rpm
  • 880ftlb torque
2011 Coupe AT
774/742 - e85
Kong x port
NW 102
Airaid CAI
BTR stage 2 cam
DW fuel pumps
2.5/9/5
flex fuel
Kooks to Borla mufflers
weapon x hx
ID 1050
TK stage 4
Circle D converter
Mighty Mouse wild
2011 Coupe AT
774/742 - e85
Kong x port
NW 102
Airaid CAI
BTR stage 2 cam
DW fuel pumps
2.5/9/5
flex fuel
weapon x hx
ID 1050
TK stage 4
Circle D converter
Mighty Mouse wild
2011 Coupe AT
774/742 - e85
Kong x port
NW 102
Airaid CAI
BTR stage 2 cam
DW fuel pumps
2.5/9/5
flex fuel
weapon x hx
ID 1050
TK stage 4
Circle D converter
Mighty Mouse wild
Hey alexts. I basically have the same setup as you minus the x port and NW102. My tuner said I am to low on fuel rail pressure ln dipping into the low 50s high 40s. This is on 80% E. Question is did you install the fuel pressure regulator as well with the DW340's? I looked at the FPCM and he is commanding more pressure, it just will not hold with higher E content. Right now I'm at 687whp 672 trq. I'm trying to get to your level, but don't want to spend money on fuel if not necessary. Rather do the x port and NW102.
Thanks
Update:
657/614 on E85 (67%) dynojet
GPTuning 2.5 cam package
2.5 upper w/ 100mm idler and solid isolator
9.2" lower pulley with ATI balancer
Deatschwerks 90 lb-hr injectors
Deatschwerks 340lph pumps
DSX flex fuel kit
Speed-Engineering 2" long tube headers w/ x-pipe & stock muffler w/ electric cutouts.
AFe CAI
Soler ported throttlebody
DMS cooling system combo w/ reinforced brick & CWA150 pump
Accel wires w/ BR7IX spark plugs
Tuned by Legendary Motorsports
  • 2013 A6 Sedan
  • 2” ARH Long System (factory mufflers haven’t installed my cutouts yet), Airaid intake w/ Dry Green filter, br7ef’s & accel ceramic wires, BMR ice tank, C&R Heat Exchanger, 1050x injectors, Remote Tune by JTC Tuning, still stock upper & lower pullies
  • E85 (was at 77% content during the pulls)
  • Dynojet
  • Car put down 570/561 (uncorrected 564/559)
