61 - 80 of 250 Posts
CT5,4and 3 still coming......V variants of all 3 are in development, whether the V’s all make the cut is TBD.
Wouldn’t be the first engine Gm shelved. The black wing will find its way into something in the line up.
GM may add this engine to its stable of crate engines to recoup some costs. If the price is not outrageous I can see it being popular in many projects. The size and power would be great for a lot of projects.
Into an Escalade is not exciting for me
Cram it into a smaller suv and make it an srt competitor the maybe ?
I don’t know if it will be the next GNX but maybe the next GXP
Doubtful since it can’t outrun the Corvette of the same model year.
It may outrun a base vette of the same year which is all the GN's did, although I dont really think anyone would care these days its not uncommon for some of these higher end sedans to spank around sports cars.
The GNX was the QUICKEST GM vehicle that model year, big engine ‘vette or not.
The problem I have with the Blackwing engine is that now it went from easy to work on engine up to European-complicated and labor intensive. To work on the heads now the turbos and all the plumbing need to come off as well as the front of the engine to access the DOHC cam chains to remove them just to pull the heads, and now the cams need to be removed also. Now to replace the head gaskets it'll cost $10,000 just like BMW's and Merc's, not $3,000-4,000 like it is on an LS engine. A lot of people say that GM's engines are behind the times with only running 2 valves per cylinder, but yet they put out just as much power or even more than the other "technologically" advanced engines. Yes, the turbo engine can be tweaked with a few computer mods of allowing more boost and adjusting the spark and fuel curve, but on the repair and parts modification end, an engine like this is a real pain to work on in the car. If this was such a good design why didn't Cadillac continue to upgrade the Northstar engine?
$3k-4K to do head gaskets in an LS?
My turbo DOHC Subaru was $1000 parts and labor to replace the head gaskets, ARP head studs and timing belt and water pump lol
The LS sounds expensive to work on! Haha
