21 - 40 of 322 Posts
What is the fluid flush supposedly doing to correct the issue?
GM engineers claims that the root cause of the issue was low quality silicon that was used and ended up dissolved and causing slippage or something, flush will clean this up, AFAIK it is not mechanical issue.
can someone post the most current TSB on the A8 shudder?
Mine is doing it too with 7000 miles. Local dealer has ‘never heard of the issue’.
Thanks to whomever has the latest TSB info. Is post #18 the latest stuff? If so, thank you to V-locity for posting that.
Will also need a competent dealer in Dallas area...
I know Sewell knows what it is, because Jay Lane got the information for me since I bought my V3 there.
Thanks sir - Good info. Sewell it is.
BTW do they jerk you around when you describe the issue or do they test for it (with right equipment vs. subjective ‘feel’) right away? How long is the car out of service?
I had the service e advisor ride with me and showed him it was doing it. that way I didn't get any BS about them not being able to reproduce it.
Update on mine. The shudder returned after a few thousand miles. I took it back to Sewell to service it again. They replaced the converter & filled it with synthetic fluid. The trans works perfectly now.
I took the service advisor for a ride so they could feel it.
I was told the root cause was the fluid allowed too much slip in the TC and it's about a 50/50 chance of it returning after the triple flush to get all the fluid out. Dealer did the flush procedure and the shudder was still there. Just got a new TC with no issues, but I haven't put too many miles on it yet.
I rode with the shop foreman and he said it's still very subjective. They use the laptop and look for the slip, but he doesn't only use that to test. He said sometimes you feel the shudder and it doesn't show up. Normally they just try to find a hill and the sweet spot, which was just above 35ish on mine and they can feel it when they put a load on it.
I have a 2018 V3 with 1,500 miles on it and I know how to test to see if it has the shudder and so far, it doesn't have it yet. My 2017 V3 had it, but that car is long gone. I just installed the AFM module this morning and it won't switch back and forth from V4 and V8, so it won't shudder when switching from V4 to V8 as the AFM module doesn't allow it to go into V4 mode. Maybe all you need is the AFM module.
How do you test for it? any specific steps, speed, ..etc?
In my case - steady cruise with slight incline is best. Any speed between 35-80. You can feel it in the car as a ‘washboard’ type vibration - but also you can watch the tach and see it rise about 100-200 rpm each time.
My car tends to shutter on certain up shifts as well. Typically 2-3 after a hard right turn (God knows why)
Mine isn’t really related to the V4/V8 switch FWIW.
I see thanks, I will keep an eye on this, because i did feel something last week like driving over bumpy/bad road for a sec.
Does your dealer try to use your mods as a warranty excuse?
it wasn't modded when I had it in the 1st time. now all it has is a CAI and a flex fuel sensor that im not even sure they would notice.
I know a guy that im going to have take care of it this time just so there are no questions.
