Stock long block; modded with up/lower pulleys, id850's, open X pipes, ported snout, 600 wheel as a daily driver has been a solid girl for 7 years.
I knew a new motor would be going in eventually. A few days ago the smell of oil burning on the exhaust pipe while driving was unusual...plus the rather noticable dark smoke behind me.
No check engine light, oil pressure was still above 20 near ideal, and it was about a mile to work.
Backed into a spot to investigate around. Saw a heavy trail of oil from backing in.
Below the oil pan near the rear was an impressive leak. Looks like that main seal finally ripped loose.
4 hrs later, checked oil dip stick, none of the 3 holes showed and just a hint on the tip was tan.
Opened a new 5 quart jug, put a few quarts in to see if it just leaked through, but her day was coming to a close.
Fired it up, pressure looked good, oil shop was just down the road so stopped in to get a second pair of eyes on it. Still leaking hard, but no exhaust smoke from the pipes or check engine light yet.
However, we noticed smoke when I pulled the oil PVC breather cap off. The shop owner said blown head gasket was in the mix most likely.
A local shop researched a year ago can pull the motor, see what can be reused or other options, skated January 31st.
Hoping the block and crank are still with us, heads still live enough to machine or port.
I'm thinking a mild build; BTR2 cam, poly motor mounts, new accessories, maybe flex fuel addition. I have a couple credits on HP Tuners MPVI3, all in time.
I'll post updates on this for posterity. Maybe nothing is salvageable, which then leads to another fun twist to the saga.
I'm about 20 minutes away from Orlando Speed World, this V will venture back for another pass someday...
