Can someone PLEASE clarify my dyno numbers?
18K views 15 replies 8 participants last post by  RocketSled
#1 ·
im being told 2 different stories about what numbers i should be using.....someone want to set this straight? i dont want to be telling people wrong numbers.
#5 ·
but which one do i use when people ask? im being told that my car made the 509/534 but with the air and weather it feels like i have 494/519....is that right? Time slip when i get home....i havent run the car yet.
#12 ·
That's strange sometimes mine feels like like 534 other times it feels like 529. We might have the same tuner.
#13 ·
My butt dyno tells me I have at least 1000rwhp. I refuse to verify with one of those inaccurate mechanical dynos. SAE correction factor using maths and stuff? Please. The jrV correction factor is more accurate.
Source: my feels
Seriously though, what are you using the information for? If it's just to tell people what you have then obviously you go with the bigger numbers. Do you brag about a 4" dick or a 9 incher? But if you want more useful numbers then use the correction factor. What the correction factor does is use math formulas to eliminate the weather and altitude variances on your engines performance to obtain real world comparable numbers you can use to more accurately gauge your cars performance. But even correction factors are only so accurate. That's why all other things being equal you get more useful information with the time slip.
#16 ·
To answer the OP's question...
Air density varies with temperature and humidity. Power varies with air density. Higher density makes more power for the same reason your V's blower makes more power. Dyno readings are normalized for "standard temperature and pressure" (something like 72ÂşF at sea level), meaning the dyno corrects its measurement for the power gain or loss due to the variance in temp/pressure over "nominal". For example, if it's colder than 72ÂşF the air density will be higher and the engine will make more power. The "corrected" measurement will be lower because the Dyno is calculating what the power would have been if the air density hadn't been above "standard". Your corrected numbers are lower, so the air density at the time you did your dyno pull was higher than normal. Your car made more power than it would have if the air was at the standard temperature and pressure.
The Dyno reports the power measured at the wheels, which is generally about 85% of the power at the motor (the 15% loss is due to friction in the driveline and accessory system). You got 509.5HP at the rear wheels. Corrected, it was 494.5HP. 509.5/0.85 is 599HP, 494.5/0.85 is 581HP at the flywheel. So the numbers you're making seem to be pretty close to what they should be.
A K&N airfilter isn't good for much additional HP in my experience. Also in my experience, Mustang Dynos tend to read a little high. So while both the corrected and not-corrected FW HP numbers are higher than advertised for the V, that doesn't necessarily mean you're making any more power than the car made when it rolled off the production line... to know if you've gotten any gains, you need a baseline measurement prior to the mod, or you need a mod that makes enough additional HP that there's no doubt it's working.
