Am I supposed to feel all the bumps on the road?
12K views 32 replies 19 participants last post by  tinman
#1 ·
Am I being 'old man' fussy or should I just accept that this is a performance car with sport tires and it's normal to feel the bumps?
I'm not sure what's going on but lately I'm really noticing it more and more. I even brought it up at the dealership when it was in for an oil change, the tech took it for a drive and said it was normal.
It's a 2017 with Michilin PS4's, just curious what other people think about it or if maybe something is wrong?
#7 ·
And how much tire wear. That, air pressure, shocks, proper suspension setting and proper suspension components along with zero additional weight in the car will all add up to answer this query. I would make sure the tires are at or one psi below the recommended pressure.
#9 ·
Brand new tires, currently sitting at 37psi. I like the slightly lower tire pressure for hooking up off the line.
Anyway, that's exactly what the dealership told me, low profile tires, low to the ground, and we admittedly have some pretty crappy roads around here.
Eh it's not really that bad I just wanted a 2nd opinion. On touring it's better than Sport, maybe I'll just set the suspension to stay on touring full time.
Oh what do you mean additional weight? 95% of the time it's just me in the car.
#19 ·
These are four door corvettes with a bit of luxury
They are not the boats caddy is renowned for in the classic age of cars. No modern cadillac will float like a 6k lb iron sled. Physics are brutally honest.
Sent from my SM-G981U using Tapatalk
Reactions: m13s
#21 ·
Definitely check if the rear shocks are leaking. I had the same experience but just assumed was normal part of the ride quality of an aggressive sport sedan in sport or track mode. Recent dealership oil change revealed rear shock leak and took pictures for me. Bit the bullet and had the rears changed out for brand new OEMs. I have a 2016 V that I picked up used a couple years ago. The ride is sooooo much better and can't believe I was driving around thinking the bumpy ride was normal. Now driving in sport or track mode with new rear shocks is like the drive feel in tour with the old shocks. Night and day difference for sure!
#28 ·
Thanks man, sounds like what I have, it's definitely in the rear, next time it's in the garage I'll ask for an inspection.
#24 ·
BOOMER
#26 ·
seriously, who heats their tires to pressurize them to the manufacturer's recommendation? wtf is wrong with people?
#27 ·
My ATS-V just got new tires last week. I followed Mfr. recommend psi at 35 on the previous set of tires. They cupped on the edges and were louder than, well, what they should be. So my new set is going to roll at 37 psi to avoid the edges wearing out prematurely. Of course I could drive like my wife.......
#29 ·
These tires are for sure sensitive to pressure. I had better times at the track at 35psi than 28psi.
