My stage 2 build and tune finally came to completion this a couple of days ago after a successful tuning session with Dr. Phil.
I'd also like to thank Kent (Larry Arizona) for answering the numerous text messages throughout my install. It was nice meeting you at the dyno session.
I also used the Camaro5 writeup here to help me. It is a great resource. I had it up on my tablet while working on the car.
http://www.camaro5.com/forums/showthread.php?t=125123
Another thing I did was use ziplock bags and labeled them. I put the bolts, nuts, ect in them and labeled the part they came from. Believe me you want to do this!
My build included adding a custom cam (from Dr. Phil), dual springs, push rods, 9.1 lower, Kooks Catted headers, ZL1 lid, and Norcal tank to my already installed Stage 1 Mods. Here are some pics and notes from the build process.
BEFORE
BUMPER COVER OFF
Track Attack Hex. It had to eventually come out in order to push the AC condenser down far enough to pull cam out. The track attack was much easier to remove and reinstall with the radiator out.
Radiator Removed. You MUST remove the fan assembly first unfortunately. I tried to cut corners and remove the assembly as a whole.
After wasting over and hour trying to "Hulk" it out, I conceded and took the fan assembly out. Even have that I had to get under the car and guide it past wire harnesses and such to get it out.
Also remember to remove transmission cooler lines and push other steel line out of the way.
BEFORE
BUMPER COVER OFF
