What kind of boost did you see with the 2650?
Do you have any info regarding the IAT's between the two?
100% Volumetric Efficiency of a 376 cid at 7000 rpm's. . .
=> (376 * 7000 / 3456)= 762 cfm
Roots blowers are not worth a 'Shit' beyond ~2.1 -ABS- Pressure Ratio.
They become very inefficient.
The pressurized air in the manifold leaks back through
the gap between the blowers vanes and case.
So if we take the 2.1 ABS ratio and multiply it into the 762 cfm
we arrive at. . .
=> (2.1 * 762)= 1600 cfm.
If everything is working correctly and using the generally accepted
conversion from cfm to hp of 1.5, we find that the potential HP would be. . .
=> ((1600 / 1.5)= 1067 fwHP.
*** I am not saying the blower won't make 1067 fwHP.
*** I am saying it won't 'in a guaranteed sense' under the
above conditions, when compared against a good 'Twin Screw'.
But that's not what is going to happen, as the blower won't
supply 1600 cfm of air at a Pr of 2.1, with an acceptable
efficiency and, the 'Density Ratio' will be far less than one
would generally see with a good 'Twin Screw' at the same Pr
. . . Under the 'Same' conditions!
This all goes back to the ability of the Twin Screw being able
to hold a much higher pressure ratio then 'Any' Roots Blower
while staying efficient.
Centrifugal and Twin Screw 'Superchargers', as well as
Turbo's, all use a very different technology to compress
the air, in order to increase mass flow, over any unit of
time, versus a Roots Blower.
A Direct Drive _ Positive Displacement Roots Style Blower
works very, very well at low rpm's, to help fill the cylinders
while the engine is operating with 'Some' low rpm range.
This provides for exceptional low rpm Torque,
but they are not known for producing Horsepower
at higher blower rpm's, or for their ability to hold
higher 'Pressure Ratios' as do the real Superchargers
I spoke off earlier.
Now, while the above is technically correct, I am happy to hear
that you are happy with your 2650 and 'Respect' your thoughts.
Different Strokes for Different Folks..
I would add to the above; the thing (other than reliability..lol) you
most likely are enjoying, is the 'Torque' that the Roots Blower
is supplying at lower engine rpm's.
Frankly, that's what I enjoy about my CTSV.. . .
