I'm planning a stereo upgrade shortly and have a few questions for you experts. I only listen to Spotify off an iPhone, and primarily listen to EDM and classic rock when driving. I'm not a true, true audiophile, so I don't feel compelled to go 3 way up front, use an active processor, or to build a custom box/amp rack.
My goal is to keep the build simple - Double DIN with CarPlay, 2 ways up front, no rear speakers, one 5 channel amp, no DSP.
Here's my planned build:
Here's my questions:
Thanks,
Jason
- Pioneer AppRadio
- Alpine PDX‑V9 or Hertz HDP5 5 channel amp
- 8" midbass in the doors
- highs in the stock tweeter location
- no rear speakers
- TBD - sub in a box or an infinite baffle sub in the deck
- a lot of dynamat
- Would you recommend the Hertz amp or the Alpine? The Alpine does have more power at 4 ohms (100W vs 75W RMS)
- Would I be better to use the highpass and bandpass of the amp to drive the highs and mids or use the AppRadio's adjustments to drive the midbass with the 'rear' channel and the highs with the 'front' channel? Looking at page 88 of the head unit manual, this appears pretty easy to do in the AppRadio.
- Am I better off running a 6.5" mid or 8" mid if I want to avoid the complexity of a 3-way setup?
- What 8" mid-bass should I look into if I want to run it at a relatively high frequency? L8v2? ZR800? MV180/182?
- Is 75W or 100W RMS at 4 Ohms enough power to drive an 8" midbass?
- What highs should I look into if I want to mount them in the factory location? the L3SE look appealing.
- Is it a dumb idea to remove the rears and just run fronts? I've never had anyone in the back of the car.
- What are the pros and cons of an infinite baffle sub in the deck (coupe) versus a sub in a box? I don't listen to a lot of rap, so I favor tighter bass. If I do a box, I lean toward something prebuilt like this 12" JL
Thanks,
Jason
