I'm looking for some input from anyone who has experience with these things, or familiarity with the general dynamics of the question that I am asking.
I installed what appears to be a 5/8" supercharger lid spacer and it comes in two pieces; one is the larger outer piece for which you need the extended bolts to bolt down the lid to the supercharger, and then there's the inner piece which has no grooves in it to match up with the inner gasket, but I made it work with some RTV.
The background to my question has to do with the RTV I applied on one side of the supercharger lid spacer (see attached photo) which seals to the intercooler brick. Due to the irregular edges around the outside of the intercooler brick, the thick rubber orange OEM gasket does a much better job creating a seal between the supercharger outlet and the brick, and easily compresses the stock 8-9 psi.
Here's where my question is. After I installed this and went for a spin, it seemes I still have 8-9 psi no problem. The intercooler brick gasket seal is only important for cooled air volume, correct?
I'm sure with the RTV, some air sneaks around the brick and doesn't get cooled. Has anybody found an alternative option to the RTV, such as a second stock gasket or similar? The problem is, the spacer doesn't have an inlay groove for the gasket to seat in.
Also, how come with the added volume to the supercharger lid I am able to get the same boost pressure as stock (with stock pulley), even though there's more volume? How come I didn't need to swap pullies to retain the same 8-9 psi boost pressure? Does the supercharger now compensate for the added volume or something?
TIA
TIA
