What's up guys! So about a few weeks ago my stabilitrak, ABS, and Traction control randomly turned off while making a tight u turn in a parking lot. Finally had somebody hook it to a scanner and this popped up:
C0045: Left Rear Wheel Speed Sensor Circuit Fault Short to Battery or Open (Symptom 05)
I did my searching and found very little. Where is this on our cars (2013 Coupe) and is it a simple fix? Also is this one of those situations where if you replace one side you might as well do the other?
Perfect timing, I'm in need of a smog check. Is this something the inspectors will fail over?
Thanks for any and all help.
