NOPOWER - 2009 Black Raven 6MT Sedan - Quest for the fastest 6MT...
124K views 719 replies 121 participants last post by  Black Moon
#1 · (Edited)
NOPOWER - 750whp/715wtq - Black Raven 6MT Sedan - Quest for the fastest 6MT...
Just updating the thread and pictures.
Pass at wannaGOFAST 1/2 mile in Clayton, GA Spring 2015
Record Holding 6MT 1/4 mile pass - 10.09 @ 150.48mph
2009 CTS-V 6MT in Black Raven
Loaded Options with Recaros
Build being done by Vengeance Racing in Cumming, GA
Personal Bests
  • 178.00mph 1/2 mile - GA wannaGOFAST 2016 Spring
  • 10.08 @ 150.48mph - Fastest 6MT CTS-V - 3rd highest recorded 1/4 mile trap speed
Motor Build
  • Stock Cube LSA Core
  • Stock LSA Crank
  • Diamond Pistons - Armor Coated and Flat Top for 10.1:1 Compression (up a point from stock) - Modified for LSA Piston Squirters
  • Callies LS Ultra H Beam Connecting Rods
  • Clevite Main and Rod Bearings
  • ARP Stud Kit
  • Custom Grind Billet Cam from VR
  • Melling Oil Pump
  • Morel Lifters
  • WCCH CNC Stage 2 Heads
  • Comp Trunion Kit
  • VR Hardened Push Rods
  • Vengeance Racing .660 lift Dual Spring Kit with Ti Retainers
  • C5R Timing Chain
  • LS7 Timing Gear
  • Ls2 Dogbone Timing Damper
  • ARP Cam Bolts
Power/Cooling - 1,215whp/1,077wtq
  • ECS Heat Exchanger
  • Aldo Welds CTSV Trunk Mount HX Tank with install kit 845.00 845.00T
  • Aldo Welds CTSV Dedicated Fuel Cell (under hood)
  • KPE Intake
  • Dual Nozzle Alky Single Nossil Mth Kit
  • fuelinjectorconnection.com 850cc Bosch Injectors
  • American Racing 2" Longtubes with Catless X-Pipe
  • VR Plug Wire Insulators
  • Metco 10 Bolt SC Hub
  • Metco 2.55" Upper Pulley
  • LPE 18% Overdrive Pulley
  • ATI Damper
  • 102mm Nick Williams TB
  • VR Catch Can
  • Vengeance Racing Ported Snout
  • Vengeance Racing Ported Blower
  • DMH Electronic Cutouts
  • Nitrous Outlet ZL1 Lid with 200 shot jets, single stage.
  • Vengeance Racing custom dual nitrous bottle mount
  • Standalone Fuel System
  • Lingenfelter RPM Limiter Timing Retard Launch Controller LSA & LS9 Engines
  • NOS Progressive Controller
  • Nitrous Outlet CTS-V Switch Panel
  • Misc Support Parts
  • ECU Tuning by Vengeance Racing
  • Stock 3.73 gear for 1/4 mile and auto 3.23 gear for DD and 1/2 mile
Drivetrain
  • RPS Street Slayer Triple Carbon Clutch
  • DSS Stage 5 Axles
Wheels/Tires/Suspension/Brakes
  • ADV.1 ADV6.2 Track Spec SL's in Matte Black Face w/Gloss Black Lip and Barrel
  • Michelin PSS 255/35/20 front 295/30/20 Rear
  • 17" Weld Racing Rears Powder Coated Satin Black
  • Eibach Coupe Spring (fronts cut 5")
  • R1 Concepts Premium Drilled and Slotted Rotors
Interior
  • Rockford Fosgate 3sixty.3
  • Alpine PDX-F4
  • Alpine PDX-V9
  • Scanspeak Discovery 10F 4" Midrange
  • DLS Iridium 8 - 8" midbasses
  • Vifa 1" silk dome tweeters
  • JPM Coachworks shift knob and shift boot (black Alcantara/blue stitching)
  • JPM Coachworks steering wheel (black Alcantara/blue stitching)
  • JPM Coachworks armrests (black Alcantara/blue stitching)
  • JPM Coachworks gauge hood (black Alcantara/blue stitching)
  • Aeroforce Gauge in clock location
Exterior
  • Chrome window trim vinyl covered with satin black
  • Satin black painted grey plastic pieces and front lip
  • Satin black painted rear chrome trim
  • Gloss vinyl wrapped and black Plastidip front grill
  • Tinted rear tail lights
  • Satin black painted chrome headlights
In the Works
How it started.
ECS HX
JPM Coachworks Interior Work
#3 · (Edited)
It's only on their Facebook page for some reason. I had mine thermo coated in grey locally so you wouldn't see the polished through the grill. The hx itself is actually made by Whitehead Motorsports. However, their "kit" comes with that D3 pump which is a piece of shit. It hangs so low you can't get the splash guards on. While I have it on my car right now, it will be taken off when the build is done.
https://www.facebook.com/media/set/?set=a.10151587283425233.1073741841.201931575232&type=3
Overall the HX is a nice unit. I originally got it from a vendor I was planning on using for this build (they are not on this site) but once I did some more homework...I decided to switch. Vengeance would have used a different unit but said the quality of this one looks good so we are going to keep it as part of the build.
#4 ·
The parts are starting to stack up. Vengeance is going to order most of them but I am ordering some odds and ends that I know I can save money on and I don't want them to price match the pricing. For example, got this damper from ATI's eBay profile that sells blemished parts that are brand new. This example had the timing marks printed twice and that's it. Otherwise...brand new for $249.99!
#5 ·
The car is also going to a vinyl guy locally this week to get the remainder of the chrome trim taken care of. I also ordered the paint and vinyl to do the calipers in Blu Caelum from Lamborghini. As of right now I am just torn on whether I am going to go with white Brembo or V logo's. Here is a photoshop render of what the final product should look like.
#9 ·
Nice! Ive spent about that much on vinyl so far trying to do it myself. Shadowline, Trimbrite, 10 yards of 30" from Fellers.com
All that and it still looks like crap! I just suck at it apparently.
The blue calipers are looking good in the rendering!
#10 ·
Yeah the cost sucks in comparison to material because it is done as a sheet to do it right which means they throw 95% of it away. I tried doing it myself and failed too. Trying to decide between matte and gloss.
#11 ·
I headed up to Monster Customs in Marietta, GA today and got my chrome window trim wrapped in satin black. It looks so much better...now I just need to paint my side vents to complete the chrome removal part of the build.
#516 ·
Chrome Trim - Wrapped vs Painted
Hello; very nice car! I've got a V coupe and I was wondering why you chose to wrap most of the chrome trim instead of paint it like you did for the side vents. Is it because you might want to have the option of the chrome trim around the windows again one day?
Thanks
#12 ·
What kind of power numbers you shooting for once the build is done?
#13 ·
850whp+ by end of Dec/Jan
#15 ·
When I get around to it I'll make a list of the spec sheet. I have it all here next to me...just need to type it up.
#16 ·
Guess I need to run nitrous now lol
Reactions: EnV
#18 ·
From the guy with a super clean wagon. Thanks man!
#22 ·
So after I got the window trim taken care of today it was time to tackle the side vents. As most of us already know, there is no way to remove these without breaking the clips. So...I got the tape and drop cloths out again with the same adhesion promoter and satin black paint that I used on the the exterior plastic and rear trunk trim and went to work.
#27 ·
We are going to have some fun with it...that is for sure. Looking forward to track days.
#29 ·
Profile shot of the black vinyl and painting after cleanup. Looks so much better than all of that chrome. Now you actually see the car as a whole instead of "ooo! shiny!". I am really happy with the end result. Now I just need to do the calipers.
#30 ·
So here is the build list for the first phase when the car goes into Vengeance Racing in October since there are some that are asking.
  • NGK TR6 Plugs
  • LPE 10 Bolt SC Hub
  • LPE 2.55" Upper Pulley
  • Meziere HX Pump
  • Vengeance Racing Custom Cam Shaft
  • VR Dual Spring Kit with Ti Retainers
  • Comp Trunion Kit
  • Melling Hi Volume Oil Pump
  • C5R Timing Chain
  • LS7 Timing Gear
  • ARP Cam Bolts
  • ATI Damper
  • 102mm TB
  • Ported Snout
  • Ported Blower
I'll run that for a little bit...and then bring her back in to get the kit I have already purchased from Nitrous Outlet through Vengeance.
  • Nitrous Outlet Direct Port ZL1 Lid setup w/-10 AN fittings
  • Vengeance Racing HX Tank
  • Nitrous Outlet Nitrous Kit
  • Lingenfelter Adjustable Launch Controller
#31 ·
subscribed!
I'm interested to see how all this comes together.
As of now my buddy/roommate holds the cts-v manual trans 1/4 mile record. He went to the track last Sunday and ran a 10.6
I'm sure he'd be devastated if someone went faster due to the fact he thinks its his purpose in life to have the fastest V.
your car is also absolutely beautiful, I'm usually not a fan of aftermarket wheels on these cars (besides the weld drag packs) but yours work so damn well. I think the blue calipers look amazing, however I think the silver on your car is perfect. definitely the best color contrast I've seen with the factory brakes. It's subtle yet not to flashy.
#59 ·
Did I miss something? Is there a video or timeslip of this magical run?
Complete shit! I was on my Michelin Pilot Super Sports for one. Traction became a big issue later on and I decided not to run until late. 12.99 @ 112 was the best we could get out of the car. It didn't want to stay hooked through 3rd. The 60 foots were insanely bad no matter how the car was launched.
I really just wanted to get some passes in before we started the build next month. It was a great time out for fun but not for getting any times down.
Even on street tires, the mph is really, really low. Did you let out at the 660' mark?
Also, what clutch do you have backing up this 900hp beast?
#32 ·
I'm in Knoxville and want Vengeance to build mine this fall/winter as well. I need to sit down with them and decide what I'm doing soon. Are you going to the GA 1/2 mile shoot out on the 13th?. VR always has great cars and customers cars there. PM sent
#33 ·
Yeah man I should be there for at least one of the days! I won't be running my car in this one but should at the events next year. Brian in GA and a couple of other Vengeance built V's will be running though.
subscribed!
Thanks! I really wanted an OEM plus look with the wheels and I think they came out great. I am really happy with them. Tell your roommate I'm coming after that time! There are quite a few MT's doing builds this fall. Should be a fun shootout.
#34 ·
A guy on Facebook was selling these for 6 bucks so I picked one up.
#36 ·
rsutton - would you mind either sharing the info on here or PM me the type of paint and adhesion promoter you used to do your side vents? I'd really appreciate it. Car looks breathtaking. The camera/man duo make it look as good as can be via Internet.
#37 ·
