1 - 5 of 5 Posts
Changing directions with my HX system and will be replacing the ZR1 pump I currently run. It has less than 20hrs of run time and works perfect I bought it brand new. I ground the mounting ribs down so the stock style band clamp could be used so it mounts in the stock location and uses the stock wiring plug and play!
These things flow plenty of water I believe the same as a non-programmed Emp. and I think they are discontinued so getting them will be more difficult. They are the best bang for the buck as far as easy swapping but not the cheapest!
$450.00 shipped
1 - 5 of 5 Posts
