Did you hold the start button for a few seconds after locking it?
Yup. Nothin. I just went out and tried again.Did you hold the start button for a few seconds after locking it?
I only have one fob, and hood is closedNeither fob will do it?
I think depending on the type of code, if it is not fixed but turned off in HPT, until that specific code is fixed, it will not auto-start. I had a "Rear Access Open" code (BCM related) and my auto-start would not work until I got new BCM and fixed the broken wire in/ on the trunk lid. The broken wire fired the BCM.I only have one fob, and hood is closed
I am not sure but check the fuse box and see if there is a fuse for the auto start. All check all the BCM fuses and make sure they are all good. I think there are about 5 or 6 of them (BCM). It will be the fuse box in the engine bay.The only codes I have are for the rear O2 sensors
Check all the BCM fuses.I thought that after my o2 sensor codes were fixed that I would be able to do it, but nope. I WAS able to get the lights to flash after I hit the lock button 2 times and held the start button but it didn’t try to start. It’s really eating at me that this isn’t working.
