1 - 9 of 9 Posts
I'm looking for a 100mm idler pulley to go with my 2.38" upper/8.66" lower setup
Please let me know if you're selling.
Thank you
Thank you
I have a 100mm and 50mm setup that I would sell.
I'd prefer not to split it up.
PM me a reasonable offer and maybe we can work something out.
Discussion Starter #4
Discussion Starter #5
Appreciate the offer, but not looking for the 50mm pulley
Discussion Starter #7
2.45/10 here with stock idlers with no issues, sure it might slip a little bit but nothing I notice.
I gain about 2psi after the shift. I need moooooore powa!
I run a UPD 105mm upper on a LFP bracket with a LFP 50mm lower.
Some brackets may interfere with the accessory drive tensioner. If this is the case...use a 70mm accessory tensioner pulley from a C6 corvette and a 1" shorter belt on that loop.
Also...on the LFP bracket I couldn't run the 105mm with the stock lower. It required a 50mm to clear.
Basically...if I had to upgrade...I'd probably just do the LPE bracket this time around and use a stock lower.
1 - 9 of 9 Posts
