1 - 16 of 16 Posts
I just wanted to post this as this seems to come up often and the answers are usually about does it fit in the wheel well. But the real answer is stock rims are 9.5 (sedan) and a 295 is the largest tire that fit the rim.
If you want larger than 295 you need larger rims, then rim size, offset and wheel well fitment is would be the questions
Note Coupe rims are 10”
As I write this I found conflicting info on the internet, 1 website has 285 and another had 295 as the largest tire for a 9.5 rim. In either case the rim is the limiting factor not the wheel well.
Not to be a naysayer here... But before I got my new wheels, I was running a 305 in the rear on my stock sedan rims. Had no issues whatsoever.
I also had 305 because the installer didn’t measure the rims correctly, didn’t have much of an issue either. What I am saying is the tire manufactures have tire size/ rim specifications that may be more of a limit than the wheel well fitment.
I am currently running 295/35/19.
Are you on stock suspension on those 295's and did you bump the front tires to a 265?
Discussion Starter #5
Stock suspension, Left the front as is, didn’t see any benefit for changing.
What about the coupe? Anyone know the widest the coupe can run? Love the real fat tires on the rear
I'm running 295/30 on stock 19 with stock suspension
Weld makes a 10.5 inch for the coupe but I run Weld 17x10 on my sedan and MT ET Street R 305 35 19 that fit without any bulging.
I'm running 345/30R20 on my coupe, stock suspension, no rubbing.
Reactions: Blades1_99
So jealous. But, I doubt Cooper makes a tire that size.
I'm running Michelin 4S and buddy they aint cheap!
Not mention the price of replacing all 4 wheels. Those couldn't have been cheap.
Tha look and the stance makes it all worth it in the end. With our cars, if you want to play you gotta pay!;)
Since I posted that 2 mo ago, I too have the 345/30 20’s. And YES! Amazing! Almost ZR1 wide
I have 20 x 10 rears (CTS-V replicas) on my V Wagon, now using Michelin 295 30s on the rear and 20 x 8.5 on front, with 255 35s. The 295s rub in touring mode, but not sport so I have to put it in sport every time I drive it, since it defaults back to touring with every start. I had 285 30s on back before with no problems, but with the 295s everyone notices that they are wider so I put up with it. Here is a picture of both my wagons together, my plum 2014 the month I got it, with the stock 19s next to my older tuscan bronze wagon that already had the 20 inch CTS V replicas, but only 285 30s in the rear at the time. Sold the bronze wagon and re-painted the 20s for the plum wagon, so the plum wagon alone with the dark wheels are the 295s. Just a subtle difference. However, Tire Rack is great since it lists the tires actual dimensions and you can see how much the same size varies from one brand to another, mostly in the width department. Hated the 285s which were Ventis V12s so I switched back to the Michelins when I went to the 295s, even though almost 50% more $
1 - 16 of 16 Posts
