1 - 7 of 7 Posts
I am wiring in a Zeitronix ZT-4 wideband to my HP Tuners Pro. The instructions for the wideband contain the following statement.
"If Analog Wideband Output or Narrowband O2 Output is used ground the Zt-4 Black wire directly at the ECU (ECM) ground. Grounding Zt-4 Black wire are other location (ex. Chassis) will result in a ground offset and false readings."
Can anybody get me an ECU pinout so I can ground this thing properly?
Also I'm wondering if using one of the ground pins on the MPVI Pro connector would be feasible, or if it is a bad idea to leave HP Tuners connected to the OBDII port full time?
Nothing wrong with leaving it connected when you are driving, just unplug when you aren't since the MPVI will leach power and kill your battery.
I leave the module plugged in and the power consumption is negligible for a car that's regularly driven.
Ive had some weird no start issues that seem to be tied to power drain through the OBD port...so I unplug all the time. My symptoms are hard to nail down though, and unpredictable at best. Good to know this works for you though!
My *best guess* is that it's not the HP Tuners module - do you have an aeroforce gauge or a wideband tied into the OBDII port or harness somehow?
Aeroforce gauge always stay plugged in.
No power lost on my heavyweight champ over the last year.
1 - 7 of 7 Posts
