1 - 4 of 4 Posts
Just purchased a wide and for the car. What is everyone using for the hot and ground for powering theirs. Did a search but only found the pink wire on the driver side panel to access. I plan to put mine where the cigarette lighter is. Can’t I just tap into those wires?
Thanks
What brand did you get? If you are using the AEM or any other brand that registers as an OBDII input you should not have an issue with using that for power and logging. If you are using the analog output to HP Tuners Pro or another logging program you may get a voltage offset issue using that for power.
I use an NGK and had a voltage offset issue I fixed.
Thanks. I ordered the AEM X series ODB II for logging with HP tuners. Thanks for the link.
You should be good to go then!
1 - 4 of 4 Posts
