1 - 8 of 8 Posts
Hey everyone... Looking to get an opinion on what to do next on the car. Here's my current specs. Mt end goal was 700rwhp but feel I can get it up a bit more (7 before having issues with rear end, drive shaft or tranny. E85 not an option.
'09 A6 Sedan w 107km: Kooks long tube w X pipe, cat delete, stock mufflers, Qtp cutouts, Airraid Cai, 2.55 upper, 9.10 lower, 850 injectors, Ngk 7xi plugs, Stage 2 cam w Johnson lifters, ice box resovoir, Track Attack Hx, AEM Meth injection, 17" drag pack , 708rwhp (best) 10.67 @ 135mph
Any thoughts?
Thanks
Larger injectors?
Ported heads(stock or aftermarket castings)
Ported blower
That’ll wake her up a bit
V Coupe Pedal car
Next incremental step would be bigger injectors then maybe porting blower, TB, then heads....
Welcome to the modness.
Or follow this crazy progression:
A Seriously Surly Coupe
2014 CTS-V Sedan A6
I'd log the IDC and see how much room you have. 850cc injectors can support something like 850-900HP at the crank. You'd need to upgrade your fuel pumps to hold the pressure before upgrading the injectors I bet.
Discussion Starter · #8 ·
Thanks guys for your replies. So from what I'm reading....
*1050 injectors.. Which I probably should have done originally grrr
* port heads, snout and blower
* Tb... Tuner recommended 90mm...should it go bigger?
I'd like to think I'd be happy from these additional mods and get her around the 750 mark.
1 - 8 of 8 Posts
