So I like the look of the Concept One CS10s but they don't make them anymore and stumbled upon the Ferrada CM2 which is scary similar, was wondering if these specs are remotely viable:
They make 19s and 20s but would like to stick with 19s.
www.elementwheels.com
Fronts: 19x9.5 with 35mm offset OR 19x8.5 with 33mm offset
Rears: 19x10.5 with 42mm offset
This seems close but I am honestly not sure if it will work. Element wheels says these particular specs "wont fit" a CTS-V but I don't know if I trust the accuracy of their site.
I'm on eibach lowering springs btw.
Thanks!
As for 20s, they have 20x9 with 35mm for front and 20x10 with 40mm for rears, as far as the closest I can find. However someone else has noted the rear pokes enough to rub on this setup.
