1 - 17 of 17 Posts
Thinking ahead to the first suggested 12,000 km window for tire rotation on the V3. Anything to consider with directionality or transferring wheel/tires from one side to the other? Size is different from back to front.....right?
I don't think you can rotate them. Different sizes front/rear and if they're directional no left/right swapping either.
For the V3, you rotate the tires one spot clockwise, so the front passenger to the rear passenger, and so on.
  • Wow
Reactions: piening2150
2017 Cadillac CTS-V
I swear, everyday the discussions here get more and more elementary. Common sense isn't so common.
Honestly, since the fronts and rears are different, you cant rotate them conventionally. If you have directional tires across the axle, you can "rotate" them by flipping the tires inside out and moving them to the opposite side. That way its still pointing the correct way but you're moving the inside of the tire to the outside kinda deal. Typically, you'll have some more camber wear on the inside than the outside to get your more life out of the tire.
But most tires nowadays are inside/out tires. You can move them to the opposite sides but you'd still have camber wear on the inside. If you're seeing more camber wear on one side/tire, wouldnt be a bad idea to check your alignment spec at that point.
2017 Cadillac CTS-V
I cant believe this thread has this many replies
Really? Dumb is funny! C'mon, man!
Reactions: Lt4Mike
2017 Cadillac CTS-V
One day we'll get past the fact that some people read the generic CTS manual that comes with the car, and think that it applies to the V. Like TIRE ROTATION, or adaptive cruise, or auto-folding mirrors, and whatever the f#ck else.
Reactions: Karch and Lt4Mike
1 - 17 of 17 Posts
