You have the basics, so good start there.
I would suggest that you consider having it tuned using HPTuners and get rid of the Diablo.
Make note of your hot idle oil pressure. With high mileage, the LSA main bearings are known to slowly get a bit sloppy.
Look at the MagRide struts for leaks.
Look at the motor mounts, we can fairly assume they are shot. They were liquid-filled and they leak a brownish fluid that will make obvious trails.
Upper control arm bushings (easy to swap entire new upper arms for cheap). Flush the brake fluid and replace the diff fluid. (use fluid containing, or add the friction modifier)
Front lower arm bushings are likely toast.
I love the car, but it is old, does have a buncha miles and it's well worth refreshing.
