Also @WookieNoizBeen doing a good bit the last few weeks. Core Shifter, V3 carbon front lip, rotors/pads and last week installed a Zl1 lid w/reinforced brick and a Varimax pump. HOLY HELL what a difference.
I had previously installed an expansion tank and low mount HX. There was always a minimum 30-35* variance in IAT2's compared to IAT1. With this new setup I'm averaging 14-17* and it drops SO fast after a pull. Incredibly happy with it.
I also spent far too many hours trying to fix my QTP cutouts. I put them on the car 5 years ago when I first got it because it was stock and far too quiet. Needless to say they stayed opened for basically the entire time. Now that I have headers and an x-pipe the car is way too loud with them open. Hit the remote, no luck. Climb under and find that the pins got pulled out of the harness god knows how long ago.
Remove the valves and solder on new harnesses for the whole set up. Check fuses, power and wouldn't you know- the ground got burned up. I'm guessing it shorted from having the open wires under the car. Get that squared away and only 1 of the cutouts will work. Swapped harnesses with the same result. Order a new motor for it, installed and still no luck. For the life of me I can't figure out the issue. Butterfly moves freely without the motor connected, motor still won't move without the butterfly connected. I need to just get rid of them I really don't feel like spending $2k on a Corsa that won't improve performance.
Did you guys have any issues getting your shifter off? I have the core shifter that I need to install soon also but have been fearing a stubborn knob... any other tips? thanks
