2961 - 2980 of 3058 Posts
Couldn't you run the relocation bracket with the stock idler? I used that with my 2.5 9.1 and the clearance is fine.
didn't have it. And if I went to it, belt would be too long.
Almost had these put on the rear, but Costco f’ed up ordering the correct fronts.
I have those same tires on mine and I hit traction control in third about 75 mph. They're brand new but just won't hold. I just bought two r888's to go on the back tomorrow. Today I installed two new door buttons on the inside. Tomorrow I'm replacing the trunk button, if that's the problem, and I have the button that goes under the trunk lid you hit from the outside.
I sure hope it’s because they are new. These will be my dedicated summer tires. With what Michelin says about them on their website, I expect good things. Toyo would be cheaper, but it looked like the 4S would be great.
I’ll find out soon enough…
Well, attempted to install my new mounts but my jack decided to take a shit as I was raising the car so that job will be on the back burner for now.
Had a side swipe laying around that came with my DDP intake so decided it was time to install. Pretty straightforward install.
Drop off to shop for the following MODS to be done below @ LMP Performance:
  • Fuel system upgrade
  • E85 sensor install
  • Plugs and wires
  • ID1300 injectors
  • KONG 2650 blower
  • Nick Williams 103 TB
  • New Tune for E85
  • Plugs and wires
  • ID1300 injectors
  • KONG 2650 blower
  • New Tune for E85
...and some rods & pistons.
2650 + SBE?
Of course not but since it's been three weeks and no damn blower I am just doing E85 conversion with fuel mods and injectors
V Coupe Pedal car
  • Plugs and wires
  • ID1300 injectors
  • KONG 2650 blower
  • New Tune for E85
What is your pulley set up?
Are you saying you think they'll hold better after I put more miles on them? Either way I've got the r888's on now. I also replaced the trunk button under the drivers side door handle, and the one on the outside of the trunk. All four buttons now work perfectly. I also bought new tags for all of my cars. The one on the CTS-V now reads GAPTIZD.
Having the 325s Michelin PS4s mounted on the 11" widened Coupe rears, to be installed later tomorrow.
Those suckers are wide.
151541
151542
151544
