Are there double pumps that can do the job?
Here's what I'd like to see from those in the know: What is the generally understood HP limit of each of these systems...
stock pumps:
DW300 X2:
DW300s + aux:
2x ANY pump model, you pick:
Fore triple:
For the DW300's + Aux. Check out what @random84 did with his car. He is in the 800's on pump with head room on e. Redoing the lines opened up room.
Opulent Unicorn motor swap: ethanol, ERL, All Pro...
I tagged you in my fuel system rant. You still targeting 66-68PSI fuel pressure? If so, when the aux turns on, what are your stock pumps doing as far as duty cycle? Are you having pressure dip issues from the stock pumps not adjusting quick enough? I changed my V relief valve out for a C7 ZR1...
Post 1198 if I didn't copy the link right.
I'll be doing the same with mine. DW300's with ALM stage 2 hat and redoing the lines between the tank and motor. I'll be running 3x 340 lph pumps essentially.
