VE data log Evaluation
797 Views 3 Replies 2 Participants Last post by  07GTS
Posting two screen shots (open/closed) of my most recent VE tuning effort. I have a few filters applied and the cell count is set at 20. Was wondering if anything stands out?
Over the past year I've learned much in the way of tuning, it's really and art/science. I have a way to go still, learning is half the fun!
Computer Personal computer Font Software Screenshot
Font Computer Personal computer Software Screenshot
2
1 - 4 of 4 Posts
open and closed dosnt matter just make sure all 3 tables are the same, the open/close is just for the engines with the adjustable intake manifold, do u watch the chart v time much with the commanded v WB overlaid is a good way to see how fueling is
yes, what I meant by open/closed was that I log with the O2 closed and open with the WB, the difference between the two.
i usually find it easier to just go OL as ur then only using fueling tables so it should be steadier, when using the trims u also have the swing of the trims within the error and sometimes that is off a little, if u can try to do sections of MAP so start low rpm and try to hold a steady map value as u increase rpm (can be hard with PD) if u do that for some lower map values and then into mid boost and full boost, once u have those and u adjust the VE to get them right u will see the look of the full VE table and u can then adjust the surrounding areas in to suit the flow of it so it should all blend together smoothly, then when u enable trims again u should see them staying closer to zero but there will always be error with trims
Reactions: 2
1 - 4 of 4 Posts
