Here you go.Any more pics? What's the actual weight compared to stock?
Thanks for the info, they are nice!Wheels are 1/2" wider in the front and 1" wider in the rear but the weights are about the same as stock. 28# give or take 1/2 pound.
You're 19x11/ 46 and 305's . At 10 o'clock on the drivers side how much space do you have between the sidewall and the inner fender ?My current setup is 19x10 +19 front and 19x11 +46 rear. 275 front, 305 rear.
Fitment.
Front could come outward further by 5mm or 10mm.
Rear: tight on the inside, nothing rubs, and fits fine on the outside. Could probably go outward 5 more mm max before rubbing so figure +41 ish.
Lowered, I don't think the offset you are thinking will work unless you go with a narrower tire, maybe stretched or with a good amount of camber.![]()
How is a spring set "pure garbage?" Not much to go wrong with a spring. Are the rates incorrect?Make sure you deal with the wheel manufacturer that knows what you plan on doing. I ordered a set a 20 inch rims while the car was at its stock ride height however when I lowered it , tire starting to rub? Trying now where it’s hitting, I have the stock set bank on. Also, used Rennick lowering springs, pure garbage , Going to put Weapon X on this week see if there’s a difference. Good luck
