1 - 6 of 6 Posts
· Administrator
Very doubtful. You’ll have to work with a chassis shop and be prepared to spend $1000’s of dollars.
You are probably better off with an aftermarket rearend.
No idea if these are any good, but from a quick search:
If the V2 diff was a direct bolt in I don't think anyone would bother with the whole subframe swap or have come up with the 8.8 swap adapters/kits. There would have been no need.
Reactions: MrSurly
Fun pedal, Few doors
* I know the V2 sub frame bolts on to the v1 *
I don't have a V1 so I don't know the story on them other than the fact that their diffs are alloy and they famously "explode".
Is your statement true? You can simply bolt a V2 cradle into a V1? seems unlikely?
Reactions: MrSurly
1 - 6 of 6 Posts
