Help please. Subject is potential excessive crankcase pressure damage and blown intake manifold seals. The following is a lot to read, but I wanted to provide as much information as possible. Thanks in advance!
Item #1 Condition:
Sporadic lean condition, wide band reads 16AFR for seconds at a time. Lean readings jump intermittently when accelerating at low and cruise rpms, sometimes lean continues until shifting into higher/lower gears, neutral, and idle. I stayed out of high rpm range to avoid lean and make it back to the garage. During the drive engine experienced no hesitation, seemed to operate normal, no high engine temps, no lean STFTs logged, no noises, logs did not reveal anything unusual.
Item #2 Condition:
Trace amount of engine oil discovered common to the oil drain plug area and lower bell housing/engine join vent. Couldn't 100% determine if oil migration originating from other areas. Borescope inspection revealed a possible trace amount of oil contamination internal bell housing. Valve cover breather had signs of oil blow-bye.
Possible Cause:
I replaced the passenger valve cover oil fill breather with a breather that has a 5/8" nipple for hose attachment, however I capped the breather nipple to avoid oil escapement from the nipple until time I installed the hose. I 'assumed' both 3/8" hoses to the catch can vented out a 5/8" hose to atmosphere would be sufficient for a couple short runs. Logged two short 5500rpm pulls and noted approximately 150hp and torque drop from previous logs. Returned home and performed an inspection.
Additional Information:
•GM B-15 long block (stock) 3k miles
•stock 1.9 SC with 3.6 pulley ratio
•1/2" phenolic plates installed between SC body and heads
•intake manifold port to valley capped
•3/8" drivers side valve cover port connected to Airaid inlet
•3/8" passenger side valve cover port connected to catch can
•3/8" valley crank case port connected to catch can
•5/8" catch can vent hose out to atmosphere
•oil fill cap replaced with breather type 5/8" hose to atmosphere
•1-2lbs less boost
•engine/oil temps 180-195*F normal
•no drops in oil press 30-53psi normal
•no drops is fuel pressure 50psi normal
•short term fuel trims, no lean or rich spikes recorded, 1.0-2.3% STFT averages
•O2s operating within normal range
•SC no unusual sounds based on previous stethoscope inspections
•engine start-up and idle normal, no rpm jumps
•engine operation overall seems normal less the current issues, no unusual sounds based on previous stethoscope inspections
•no knock or misfires logged both days
•belts (no slip), pulleys (no over heating), accessories all normal, no unusual sounds based on previous stethoscope inspections
•transmission normal operation
•worn clutch previously noted slipping (replacement planned)
•Added a can of RP engine cleaner to a full tank of 92 prior to issues, currently down to half a tank, most likely not a factor, just throwing it out there
Driving the past couple weeks the only other unusual issue that comes to mind is an occasional faint odor of burnt rubber in the area between the block and bell housing upon engine shutdown, drivers side. I checked belts and verified hose and header clearances, tires weren't the source, still undetermined source of burnt rubber odor?
My fear is I have managed to cause damage to my rear main seal? I already confirmed I blew my intake manifold seals via water test. The intake manifold seals are not stock, I have phenolic spacer plates installed using high temp RTV filled channels. I have a revised set of plates I plan to fabricate CMP-4000 (material) gaskets.
Some questions I have are:
Thanks again for your help!
Item #1 Condition:
Item #2 Condition:
Possible Cause:
•1-2lbs less boost
- Can a failing rear main seal cause a burnt rubber odor?
- Why do my STFTs not register the unmetered manifold air leak as lean, even with a high hit count?
- Is it best to completely remove the rear engine cover when replacing a main seal, and if so, is it good practice to remove and replace the oil pan gasket as well?
- Opinions, Mcleod standard RXT vs RXT-HD?
