1 - 9 of 9 Posts
Thank you in advance for the help.
If one compares my low 92 octane spark table to my high octane (toluene 96 estimate) table it appears in the 1.74-2.0 spark airmass areas there is a shift of retard that occurs? The lower octane table retards between 4400-4800rpm, the higher octane table retards between 3600-4000rpm. Why is this? Is there something I can change to allow advance in these areas? Does it matter?
NOTE: When comparing tables add 0.5-3.0* to the 92 table, forgot to zero the PE/COT modifier at the time. The toluene table reflects actuals.
(see attachments) ty
Rectangle Font Material property Circle Technology
Colorfulness Light Rectangle Line Font
Computer Personal computer Light Font Display device
would prob have to see it on a dyno to see if ur actually loosing torque or not, or could just be the resistance to knock affecting it as just going by knock only shows when u have gone too far on petrol or way too far on toluene or way way way too far on ethanol :unsure:
I will log some more, I was also thinking it may be I need to add a bit more fuel between 3600-4000, I'm at high cylinder mass with considerable boost? Attached is another screen shoot, I little less choppy. You can see the slight knock event 3600-4000. I was coming off the gas at this point in the screen shot, definitely had more power, but I am limited to the street so I have to be careful, Sunday afternoon is the only time I can really get anything done with less traffic around.
Computer Font Personal computer Display device Technology
think i posted a while ago the maths u can put in the hpt chart v time that gives u a value of acceleration then u can actually see if ur gaining speed or not with the timing adjustments, if u didnt see it let me know ill put it in here
If you wouldn't mind, post it again, may have missed it?
maths is ([8001.113.avg(-1500)]) - ([8001.113.avg(1500)]) u have to log ''undriven wheelspeed'' so ur using the front wheels so not wheel spin can affect it, use scale of say -40 to 40 so its basically the wheel speed against itself over time past and future so if its increasing in acceleration the number will go higher, if u want a different value output u can play with the time in each 1500 or -1500 if u change one change both the same but should be fine as is
Is this a filter or the set up for a graph
1 - 9 of 9 Posts
