1. Tell that dealer to find the bridge in his fantasyland, & jump the fuck off a it.Questions - GM or Mobil 1 ? filter change or complete exchange / dealer want $480 for fluid , filter, and gasket?
not sure what to do............
2018 42K no trans Sutter
thanks
How do you tell if has upgrade ATF? they want to use AW-1 ATF @ $39 quart. Can I just use Mobil 1 LV ATF HP blue label?1. Tell that dealer to find the bridge in his fantasyland, & jump the fuck off a it.
2. If you DO NOT have the upgraded trans fluid, flush and refill the system.
3. If you already DO have the upgraded trans fluid, don't flush. You get more problems after flushing because contaminants are blown around. Just filter, oil, gasket, and done.
4. SEE #1
If you have the 8L90 that is the only fluid to use!Can I just use Mobil 1 LV ATF HP blue label?
The Mobil 1 or the GM ATF?If you have the 8L90 that is the only fluid to use!
You MUST use the Mobil 1 specified by the recall. Anything else will give you trouble.The Mobil 1 or the GM ATF?
are you using the mobile 1 blue label?The dealer is using a flush machine and I'm sure charging you a premium per quart for this fluid. Sadly this is not too far off on the price. If they dont want to use the specified fluid that is already a red flag. Me personally if the trans is running ok, I would drop the pan, change the filter and top it off. However this wont touch the fluid in the TC, cooler and some circuits. You probably get about 1/3 new fluid this way? Draining and refilling the trans a few times over a short period of time would get a little more fresh fluid in there too.
What I have also done on other cars is use the trans pump to do a flush. Pretty much you disconnect a cooler hose, the outlet side goes into a bucket and the inlet hose gets a funnel jammed in it that stays full of fresh ATF. Start the car. When you start to see fresh fluid come out of the other end you are done. Then check the level in the trans to be sure. This ensures you get all new fluid but is gentler than a pressurized flush machine that may dislodge junk in your trans.
My V has 34K miles I havent done anything with the ATF yet.are you using the mobile 1 blue label?
