1 - 20 of 34 Posts
2014 coupe
I’ve finally had enough with the infamous “cold scraping” sound our V’s make. I’ve done a lot of searching around to see what others have done. I came to the conclusion that is was my upper control arm bushings.
So I pulled the strut assembly out and pulled off my UCA. The bushings looked fine. Upon further inspection the spring insulator had some cracks. I’ll update how it goes once I get those replaced. What do you guys think of the control arm bushing? They looked fine to me.
Automotive tire Motor vehicle Bumper Rim Gas
White Light Automotive tire Yellow Font
Automotive tire Leg Wood Gas Bicycle part
Automotive tire Bicycle part Wood Rim Automotive wheel system
Automotive tire Wood Bicycle part Rim Gas
Automotive tire Motor vehicle Wheel Automotive design Tire
So I pulled the strut assembly out and pulled off my UCA. The bushings looked fine. Upon further inspection the spring insulator had some cracks. I’ll update how it goes once I get those replaced. What do you guys think of the control arm bushing? They looked fine to me. View attachment 155348 View attachment 155349 View attachment 155350 View attachment 155351 View attachment 155352 View attachment 155353
I'm on the same boat. Now this it is getting cold outside it is starting to make a lot more noise in the mornings. Your UCA look fine. One area looks like its suspicious (the second and fourth picture)
More Information for GM GENUINE 15840310 (rockauto.com)
2014 coupe
I’m gonna call around some dealers tomorrow and see if they have this part in stock. I was looking at GM part number 22935187. The one you referenced cost less.
Mine sounded horrible this morning and it's not even that cold here. Sound was coming from the right front. :(
Mine does it too. Sounds like rubber scraping
It is an easy changeout if you just replace the upper control arms. You can change the upper control arm bushings to urethane and they work great. However, the upper ball joint will need replacement too. Your call if you want to do the urethane or not. Just be sure you tighten the control arm bolts once you have the car at ride height otherwise the bushings will have preload.
I thought preload was only for swaybars, endlinks and the top bolt of the strut tower. How can you tighten the UCA bolts once the car is on the ground? I'm on Eibachs and can barley get a finger between the tire and fender......?
you sit the lower control arm on a jack and do the same thing on the other side. Once the car is level tighten the bolt and nut. I have established long wrenches and that is how I got to them. Pain in the ass. If your bushings are not torn and you mark the location you could put the others in the same orientation. But, you do risk preloading the control arms doing it that way.
The urethane bushing install was not very easy when i did it. But yes the uca rots out and makes noises. That one pictures looks a lot better than mine did
2014 coupe
Discussion Starter · #12 ·
My UCA bushings are fine.
I ordered part number 15840310 and it was the wrong part. I need 22935187. The upper insulator in the V is a one piece assembly with a dust cover for the strut. I’ll post a picture of what the old one vs new one when I get it in, but here is a picture of the part I have to try returning. Mine looks collapsed.
Automotive tire Gas Auto part Jewellery Metal
I wish mine was just a scrape sound.. it feels like the front end is gonna fall out when it's cold and I turn sharp.. its a big clunk and you can feel it! Car drives smooth as can be and after 5 mins on the road, you can turn in circles with no sound of front end movement...
2014 coupe
Discussion Starter · #18 ·
We are all watching
I got it in the car last night, but ran out of time. I need to put the wheel back on and check the other side before test driving. I had a hell of a time trying to get the right torque for the UCA. I went with 35 ft/lb. Also lost the Jesus clip for a little bit, but he returned.
Automotive tire Automotive wheel system Rim Gas Auto part
Got the wheel back on and it’s sitting on the floor. It’s definitely sitting higher. Just by looking between the fender and tire. I can see the passenger side is in the same condition. I need to order another for the passenger side. Rockauto now shows it out of stock. So I’ll have to go either GMpartsdirect or have the dealer order it. Both are saying about 7-10 days. One local dealer ship showed they had 2 in stock but when they physically looked they could not be found. So goes the story of the backyard mechanic.
Grille Vehicle Tire Hood Car
Ruler Temperature Office ruler Tape measure Tool
Tape measure Tool Measuring instrument Material property Ruler
So quick update, I"m having trouble ordering another upper insulator. Rock Auto shows out of stock. I tried GMpartsonline and they rejected my order because its high risk. They offered to send me a paypal invoice, which i agreed. But I haven't heard anything back. So I went to the dealership and the parts counter is having trouble ordering it also. The part is paid for but I guess we'll see what happens.
Not related but if your interested rock auto sells the three piece grey oem splitter for the cheapest price around. Noticed yours was kind of jacked up in the pic. Will clean up your front end.
Reactions: Lou
2014 coupe
Discussion Starter · #20 ·
It’s been on my mind to replace just haven’t got around to looking at prices yet. How much are they asking? Do you have a part number? I’m lazy to do any searching right now.
1 - 20 of 34 Posts
