So my test drive didnt go well. First thing I did was connect HPtuners Pro to the AEM wideband obd2 connector, and read the ECM/TCM/FSCM. Saved that file and fired up the scanner. After a little warm up drive I got on it a bit and it threw a CEL. Immediately after the pull, I could feel the ABS system vibrating my brake pedal. The wideband read 11.4ish at WOT. I pulled the codes and there seems to be some type of communication problem.
Ill post a pic cause theres too much to type. The PO just replaced the front LCAs.
I'm going to start searching the web to see if this is a common problem, but figured I'd check here first.
I've heard that reading the tune file can sometimes cause this loss of communication for a cycle. I'll try clearing the codes. But the C0615 needs to be checked. The LCAs were just replaced. They probably fucked it.
