1 - 3 of 3 Posts
Hey CTS-V owners this has been covered a lot of times however I can't locate an exact answer. I want new tires for my 2018 V. The stock tires are OK more traction is wanted though. Would it be OK to put Pilot 4S P305/30R19 in the rear and P275/35R19 in the front? Would this cause any traction control issues and would there be any issues with drivability?
Thanks for the help
I can't answer your question directly because I've got a V2. But... you have to maintain the same front/rear tire diameter ratio or you will have an effect on TC. If the rear tires have a smaller diameter, TC will kick on sooner. If they have a larger diameter, it'll kick in later. I've used this method to "tune" TC on my GM cars to be more to my liking (I want a little more wheelspin before TC engages so I oversize the rear tire diameter a bit).
As for the tires, the question you want to ask is "how wide is the rim?". The tire will have a "nominal" and a upper and lower limit for wheel width. If your rims don't violate those limits, you can mount the tire without fear of rubbing (as long as you're not increasing the diameter much) or of the tire coming off the rim. But if the tire width is at the upper limit for your wheel size, handling will be negatively affected (the car will "squirm" because the tire geometry will allow more sidewall flex). Good tire geometry is slightly wider where the tire meets the rim than at the tread.
You're V has 35 front and 30 rear aspect ratio I'm stock form so for clarity the aspect ratios on the sizes you are asking about is fine. I do not have experience with 305 rear but think it's ok from what I understand. If you are looking just for more traction on launch, I don't think you will find any with 305 vs 295 with same wheel. You can look up what the contact patch would be with each on the same wheel. Only thing that's gonna help is an r compound tire imo. Nothing wrong trying things, I just always found thie uosize to not be worth the $$ over the years
1 - 3 of 3 Posts
