Tire recommendations for new to me V2
1211 Views 27 Replies 15 Participants Last post by  BlueCoupeV
So my new V2 has tires that are trashed and the first thing I need to do is get new rubber. I've read a ton of threads. The car has coupe wheels on the rear. I'm planning on 295/35/19 on the back and 255/40/19 on the front. I know I could go 305 on the rear but may lower it at some point.
I've mostly narrowed the rears down to:
R888Rs
NT555R2
PS4s
I'm open to other suggestions but these seem to be popular. I want to be able to hook, get some miles, and be able to get home if I get caught in the rain.
I'll have a drag pack for dedicated track time. Also the car should be putting down around 750+.
I also have no idea which tires to run in the front to mate with those rear options.
If anyone has personal experience or just sound advice on a direction to go please let me know. I want to get these ordered up so when the car gets here I can slap some sticky on.
21 - 28 of 28 Posts
If your tires are directional (the Ventus ARE) , swapping side to side is out as well.
Well... only if you don't own a tire changing machine. You can swap 'em, but you have to swap the rims, you can't just swap the tire+rim (unless you drive backwards mostly).
I used to run those stupid Goodyear Gatorback tires and had a deal with the local tire shop to give me a break on swapping. But ultimately I just "challenged" myself to wear my tires out fast enough that tire rotation isn't a consideration.
In all seriousness, though, the rubber on a car tire isn't "homogeneous", it's not the same throughout. The rubber at the face of the tread on a new tire is softer than the rubber deeper down. The more the tire wears, the harder the exposed rubber becomes (which is why a bald tire doesn't work the same as a drag tire, when the tire has worn to the carcass the rubber is more like a hockey puck than a pencil eraser).
What the US DOT dictates as minimum acceptable tread depth is well past the point a tire is going to perform like when it was new. Buy the unidirectional tires if you want. Properly align the car and IMO, if the tires get to the point you need to think about swapping them left/right, you should just be thinking about replacing them instead.
Well I slept on the Discount Tire $100 off Michelins because I'm still undecided. I'm not broke but also not living in luxury so replacing tires every 3000 miles isn't really in the cards.
If you don't plan on replacing them very often, it can only be because you don't plan on driving the car a lot, or very hard. So you probably don't need the widest, stickiest tire you can buy.
I've been very happy with Pilot Sports over the years. Probably the tire I've bought the most often (and I do go through tires pretty quick, and have been in the habit of doing so for decades). Good balance between performance and durability.
Costco is having sale on Michelins. 150 bucks off. They also come with a 5 year road hazard warranty.
Reactions: 2
I just replaced the Extreme contact Continentals on the back of my DD. It had 25,000. I live in AZ, heat on the roads does not help, I have lived in the rain / snow in WA, with different tires for the weather, like the heat.
Thanks for the heads up. I may jump on this. Need to find out what the costco membership costs. I'm a Sam's Club guy.
I've always had good luck with the extreme contacts. 325's on the back, 265's up front.
Of course with just under a million whp, no tire is gonna grip well below 50mph but the conti's are a pretty good balance for grip and wear.
I run the Cup 2Rs on the rear, 305s and Ps4s on the front. They grab excellent and are a tire you can still enjoy high speed cornering. Best tire ive ever used, its just pricey.
21 - 28 of 28 Posts
