1 - 20 of 304 Posts
I figured I would start a thread to document my build.
Summary of work and parts list:
Forged internals / engine machining / assembly / custom oil pan gate - Sloan Racing Engines
Twin turbo kit - Huron Speed
LS3 intake with gaskets and bolts - RPM (Garner NC)
Fore Fuel systems LS3 fuel rails - LT1Z
Melling oil pump - LT1Z
Custom grind cam - LT1Z
Johnson lifters - LT1Z
Circle D convertor - Rick Crawford Racing
Custom valve job / head porting - Rick Crawford Racing
ID1300 injectors - Rick Crawford Racing
TurboSmart EBOOST2 controller - Amazon
Custom poly motor mounts - Adam112
Custom defroster vent gauge pod- BlueCoupeV
Wideband - Florida-vee
Installation was done by me in my home garage. Yes my back hurts LOL
Get it!!!!!!!!!!!!!
I am one of the other folks that pulled the trigger on the early kit. I have received the same components that you have so far and look forward to making progress with the new setup!
What turbos did you chose?
Using the fore in-tank system?
Discussion Starter #9
HS branded Comp turbos
Yes - reusing the fuel system that is already there
Let me know if you guys ned help. We dont have the same turbo kit but as far as intake, vacuum lines, etc. it should be the same. I can probably be of some assistance if you run into a speedbump. I also have a fore triple pump system.
Discussion Starter #11
Thanks Manny.
I may reach out to you to compare notes / ideas.
David
Thanks Manny.
David
You better start posting pics too. None of this "got my turbos" and "going to dyno in a week" and then we never hear from you again kind of shit.
Discussion Starter #13
Will do! I am making progress but not as quickly as anyone would like. Ran into some delays with the engine builder. Mainly waiting on a bunch of parts to arrive (included the WeaponX hood I paid for back in July 2017).
Here is a link to my 2007 Procharged TBSS build if that will hold anyone over:
Jolly ole St. Nick came to my house early! - Chevy Trailblazer SS Forum
Stand by for updates :cool:
Followed the SS build from start and now here to see the TT-V build. Looking forward to a clean, detailed build as thats how you do.. feb cant come quick enough...
Sent from my boujea ass phone
Following as well as your just up the road from me. I'm in Columbia SC, and will be going after this set up when I get back in 6 months.
Discussion Starter #16
Kit just arrived
1 - 20 of 304 Posts
