Test pipes
1299 Views 4 Replies 5 Participants Last post by  jcs003
I’m in search of test pipes for a V2.
1 - 5 of 5 Posts
If you find some there's one thing to check and one to buy before installing. It's very common for the end that connects to the exhaust manifold to not be perfectly flat. It then burns through the gasket and you have a leak. Check and grind if necessary. There's a post on here about an alternative gasket It's got a metal center with a ring that seals better than a flat gasket. I bought those and they work real well. Been a couple of years with no leaks.
Reactions: 2
Vladi at Street Driven Performance sells some.
Similar to BB’s, but cheaper.
It would work better for you to get a full system which would include cat delete and would provide more performance.
1 - 5 of 5 Posts
