1 - 3 of 3 Posts
I had a new torque converter installed in my TBSS. During easy driving the lockup is cycling pretty often. The new converter is an FTI 3200 triple disk replacing a Yank 3600 for those who care. My trans guy said to look at the TCC Duty Cycle. I've checked the HP Tuners forum and didn't find much agreement on the values to use for minimum.
Here's the current values in the tune:
Colorfulness Rectangle Slope Font Line
Most forum posts said to set maximum to 100. I think there's little to be gained over the current values. For minimum I see posts starting from using values of 50 all the way up to 90. I saw many responses to the suggestion of 50 that it was too low. I'm thinking about starting in the 50s and gradually increasing depending on how it drives. Two questions:
1) If I change the values should I replace all the cells or add the amount to each cell? Using 50 I would have values from 57 to 71.
2) Where would you suggest starting out? Even if I add a number to each cell, I wouldn't go over 90 in any cell initially so would reduce the higher numbers if necessary.
I'm posting here because the most knowledgeable TBSS owners have moved on to other vehicles. A number are on here. I know one other who has both like I do.
Thanks for responding. I got a group of local owners and worked it out over the summer.
1 - 3 of 3 Posts
