You want the 305/45/17 ET street R. The 275 adds to much "ratio". The 305 should just barely rub on a big bump. I would get the slightest amount of rubber on the inside of the drivers side fender lip, but it never did any damage to the tire.
What are the specs (offset & width) for wheels that will work with the 305/45/17 Street R tires?You want the 305/45/17 ET street R. The 275 adds to much "ratio". The 305 should just barely rub on a big bump. I would get the slightest amount of rubber on the inside of the drivers side fender lip, but it never did any damage to the tire.
For a sedan 17x10 is the right size wheel. How much power do you have? In the stratosphere you may want a beadlock. Just go to Mont Motorsports V2 Wheels and check out the options. Can't go smaller than a 17" wheel and clear the stock brakes.What are the specs (offset & width) for wheels that will work with the 305/45/17 Street R tires?
We have both Weld and Forgestar for these cars in 17 and 18” sizes..What are the specs (offset & width) for wheels that will work with the 305/45/17 Street R tires?
Thank you for your help.
I run 305/35-19 drag radials full timeI've heard chatter that there's a drag radial setup on a 19" wheel that works well enough on the street... Anybody have experience with that? Car is going on the dyno today (hopefully) and I'm probably looking at around 800whp on my normal every day tune...I know I'm going to have to swap to a DR to be able to use ANY of that power, and I'd like to not have to buy new wheels just yet.
Depends on the sizeWhat are the offsets on the Weld and Forgestar wheels?
Sedan or coupe? Which tire are you running?I run 305/35-19 drag radials full time
Sedan. Running Nitto NT05R.Sedan or coupe? Which tire are you running?
M&H run smaller too.Need to be careful when comparing the same size tire from different companies, the Nittos run smaller than both Toyo and M/T's. If there is no chance of running into rain then the ET Street R is a fantastic tire.
