What if you use the hydraulic method (I used wet strips of paper on a different crank once) but use a piece of metal to close off the crank oil plug? Like a dime for ex?
Also, harbor freight sells bearing pullers that get far better engagement than a two pronged slide hammer attachment. I used one of those along with some threaded Rod to do blower case bearings, and probably the pilot come to think of it. With threaded Rod, hardened hardware, and some plate steel welded in a U, you’ve got a puller you can run with an impact
Ps the slide hammer has never been used. Match thread with some Rod and build tool.
