Goal of this build was to completely replace the stock stereo, but do so with no permanent modifications and nothing visible other than the headunit. Wiring adapters were used whenever possible.
Primary components:
I installed the electronics where the factory CD player goes. This keeps all of the wiring short and low.
I used the bracket that would normally hold the screen to the electronics box for my mounting adapter. This is then installed using factory mounting bolts.
Some minor trimming of the part of the console which holds the clock is required, to clear the bottom of the screen mounting bracket, but every single screw hole required to mount the clock assembly is still present. The Stinger screen mounting bracket almost perfectly fits into the area in the center (near the Cadillac logo).
This is the bracket that would normally go on top of the electronics box to hold the screen. I used it here by itself. The Metra dash kit brackets did need to be trimmed to clear my not-trimmed factory dash. These screws holding the Metra kit in place were later replaced with the factory bolts. The backup camera adapter is also visible.
The amp in the rear and the crossovers are mounted exactly where the factor amp mounts. The purple, green, grey, brown, etc. wires into the crossover are from the Metra amp bypass kit. All speakers are driven by factory wiring. The power cables shown here run across the lower deck inside the hollow area in the sheet metal directly to the battery on the other side of the trunk.
More pictures and info in the next post.
Tim
Primary components:
- Stinger Heigh10 headunit
- JL Audio VX1000/5i amplifier + DRC-205 volume control knob
- Illusion Audio C8 component speakers
- OEM non-nav radio cover
- I wanted a Stinger Elev8 and ordered one, but it was discontinued and a Heigh10 was delivered. The only real difference between the two is the screen size/style. Excellent audio quality and digital signal direct from my iPhone to the amp. The screen detaches from the electronics, so you can install this without ruining your center console. I think this is the only current non-Chinese head unit with digital output and CarPlay.
- JL Audio VX1000/5i. Digital input + DSP allows rear deck speakers to be used for differential rear fill. They're bandpassed and do L-R. Alternately, I could delete the rear fill and run fully active on the front stage or run C8 woofers in the doors + C3CX (or another similar speaker) in the dash. No potential for ground loops or other noise through RCA cables. Minimum weight and minimal cabling. Super tiny- fits exactly where the stock amp sits.
- Illusion Audio C8 components- I bought these a long time ago. They fit perfectly. The door speakers currently have a 40 hz high pass and sound very nice. The tweeters are a bit hot, but they're set at -0. I may tune them via the crossover, or via the VXi amp.
- 15 foot Toslink cable
- 10 ft ethernet cable
- 10 ft usb extension cable
- 4 gauge wire, < 15 ft run directly from amp to battery
- JL Audio XD-MFBW-MAXI fuse box
- JL Audio XD-MAXI-80 80 80 amp fuse
- NVX XRTC4 4 gauge ring terminal
- 22 gauge TXL turn-on wire
- Wire sheathing
- Tesa tape
- Heat shrink
- Metra 99-3018HG dash kit
- Metra ASWC steering wheel adapter
- Metra 40-EU10 radio antenna adapter
- Metra BACKUPCAM-2 rear camera adapter
- 2x sets Metra 72-4568 Speaker Harness adapter
- Metra 70-2057 amp bypass harness
- USB 3.0 and HDMI cigarette lighter adapter
- 1/2" HDPE from McMaster for door speaker adapters and amp rack
- 1/4" HDPE from McMaster for amp rack
- 1/2" foam between door speaker and door
- 3/16" rubber foam for between door speaker adapters and factory Bose bracket
Tim
