1 - 9 of 9 Posts
I don't have a starter yet for this LSA swap and I have a buddy with an LS-3 Camaro that has a weak sauce OEM starter. I've heard it's an issue with those cars, does the same issue plague the LSA? Same starter or different?
Since my motor is 403" with 11:1 and LSA, I don't want a weakling starter, what do you guys recommend?
Discussion Starter · #4 ·
Discussion Starter · #6 ·
No but why does that matter to start up?
We do have 11:1 blower engines too no problem
The rotational mass of the blower and the fact it's positive displacement.
Yeah 11:1 is where I'm at so that's a good sign!
stock LS2 is 10.9 comp and stock starter is fine, then u add a camshaft which will lower dynamic compression during cranking so the actual static comp dosnt matter as it will be easier then a stock cam with same compression to turn over
Discussion Starter · #8 ·
So LS2 or LS3 starter? I see a lot of people saying the LS3 is stronger and smaller? These Holley headers should clear either one, I would think, but I'll have to verify.
Discussion Starter · #9 ·
Bump
1 - 9 of 9 Posts
