The sensor is located on the steering column, behind the steering wheel. You have to take the wheel off, and the plastic housing around the column to get to it. Don't remember what else has to come off. Pull the battery before you start the job, and when you reconnect everything do it without someone sitting in the driver's seat in case the steering column air bag blows...
You should clear both codes and see if they come back right away. Both are labeled "C" meaning "Current" meaning the faults were detected on the current ignition cycle. The C0899 may be part of the problem. Though the C0710 is almost definitely the primary issue. The error code means the sensor is still functioning but it's "noisy" and the BCM doesn't think the sensor is reliable. Won't be a problem for you unless you're in a loss-of-traction situation. Steering Wheel angle is used for Active Handling and ABS.
