looks great!
Looking good, have you thought about putting hub centric spacers on it to make the wheels sit flush with the fenders? I have a sedan on coupe Eibachs with 15mm spacers on all four corners and it looks sleek.Sits pretty nice and rides better than I thought it would
Hadn’t thought about it. Can I see a picture of how your car looks with the spacers? Do you have any rubbing when you hit a bump? I was thinking about wider tires.Looking good, have you thought about putting hub centric spacers on it to make the wheels sit flush with the fenders? I have a sedan on coupe Eibachs with 15mm spacers on all four corners and it looks sleek.
Mr. Big actually owns a Moped.Looking good, have you thought about putting hub centric spacers on it to make the wheels sit flush with the fenders? I have a sedan on coupe Eibachs with 15mm spacers on all four corners and it looks sleek.
lmboMr. Big actually owns a Moped.
That's actually his neighbors car.
His neighbor called me and asked if this is a good idea. . .
I told him yes, so he is now considering proceeding with that.
His neighbor sent me a picture of Mr. Big on his Moped.
I don't have a picture off hand, but I did post it up on here somewhere a while back. Type in 15mm spacers and you'll come across some threads.lmbo
No rubbing and I am on OEM size wheels & tires.Hadn’t thought about it. Can I see a picture of how your car looks with the spacers? Do you have any rubbing when you hit a bump? I was thinking about wider tires.
Noob question...Eibachs coupe springs gives lower stance if installed on sedans?Looking good, have you thought about putting hub centric spacers on it to make the wheels sit flush with the fenders? I have a sedan on coupe Eibachs with 15mm spacers on all four corners and it looks sleek.
They bring down the rear a little more than the sedan springs. Some cut a little off the front springs for a better rake look.Noob question...Eibachs coupe springs gives lower stance if installed on sedans?
