1 - 15 of 15 Posts
2011 cts v coupe
Went out to the track last night to get some data. It was hot. 98 degrees, 13% humidity. It was a fun night but so so frustrating as I was close to touching a 10 but couldn’t make it happen. Car is pulling timing for some reason right out of the hole and I believe again up top as I saw my iat2’s go to 160. With my cooling mods they recovered super fast, however last night has swayed me to put a basic water/meth kit on the car. Going to install that and try and go 1 more time before I swap to the ported blower.
Nice, what was the DA then?
Would you consider putting your build into your signature line, please.. ;)
Reactions: MrSurly
2011 cts v coupe
Discussion Starter · #4 ·
Lol anything for you duck
2011 cts v coupe
Sooooo how do I do my signature? Lol
Sometimes, when a poster is having issues, viewing their build can help.
Particularly their camshaft valve events, TB size, cylinder heads, and pulley sizes.. ;)
Rectangle Azure Font Screenshot Parallel
2011 cts v coupe
Discussion Starter · #8 ·
Ah ok. Might have to do it from my laptop instead of my phone
2011 cts v coupe
Discussion Starter · #9 ·
Got it!
2011 cts v coupe
Discussion Starter · #11 ·
Stock heads stock cam stock blower
Stock cam?
With that combo, your not doing bad..:)
The only reason your seeing the boost you are, is because boost itself, is simply a resistance to air flow.
If we remove the air restrictions within the induction system,
boost goes down, but VE% goes up. . . So now one would
desire to overdrive the blower more.
Once your VE% can deliver more than 100% cylinder fill, then we
move on to describing cylinder fill, by stating it as %VE.
100% cylinder fill for a 376 cid engine, yields above 755 fwHP, to 785 fwHP. A safe cylinder fill would be about 87%, or approximately 660 hp.
A better cam, and an increase in pulley ratio, will get you much more.
Then you can move on to a better cylinder head if you wish.
You might want to add what fuel your using to your signature line also.
I know, picky, picky, picky. . lol
2011 cts v coupe
Discussion Starter · #13 ·
Lol jeeeeeeeez let’s do everything rubberduck wants to do! I kid I kid.
I’m using torco e98.
New motor is getting heads cam and lower pulley. And I’ll swap the ported blower over also.
Think I might switch to ET street R after these SS are done. Need to get 60 foots down from 1.6
And if you do everything I tell you to do, you’ll have to go to the bank and take out a very large loan… L O L
But you seem to be well on your way to spending large volumes of dollars, without my help..😃
2011 cts v coupe
Discussion Starter · #15 ·
Yeah I’m well on the way lol. Already talking to my buddy to pick up his Gforce rear end, axles and 15in conversion.
I seem to only pick expensive hobbies. Cars, competitive shooting, etc.
1 - 15 of 15 Posts
